Solaris AGG Compile...
Nolte, Tim
Tim.Nolte at IPCSWIRELESSINC.COM
Wed Oct 17 13:32:33 EDT 2007
OK, I'm still struggling here. Here is how I modified my
Makefile.in.SunOS:
Changed:
CXX = CC
To:
CXX = gcc
Changed:
C = cc
To:
C = gcc
Added:
AR = ar
LD = ld
Changed:
LIB = CC -xar -o
To:
LIB = g++ -xar -o
I've also made the change of renaming /usr/ccs/bin/ld to
/usr/ccs/bin/ld-off during the AGG build process. Here is what I'm
getting as output:
cd src; make
make[1]: Entering directory `/usr/local/agg-2.4/src'
g++ -c -O3 -I/usr/openwin/include -L/usr/openwin/lib -I../include -L./
agg_arc.cpp -o agg_arc.o
agg_arrowhead.cpp -o agg_arrowhead.o
agg_bezier_arc.cpp -o agg_bezier_arc.o
agg_bspline.cpp -o agg_bspline.o
agg_curves.cpp -o agg_curves.o
agg_vcgen_contour.cpp -o agg_vcgen_contour.o
agg_vcgen_dash.cpp -o agg_vcgen_dash.o
agg_vcgen_markers_term.cpp -o agg_vcgen_markers_term.o
agg_vcgen_smooth_poly1.cpp -o agg_vcgen_smooth_poly1.o
agg_vcgen_stroke.cpp -o agg_vcgen_stroke.o
agg_vcgen_bspline.cpp -o agg_vcgen_bspline.o
agg_gsv_text.cpp -o agg_gsv_text.o
agg_image_filters.cpp -o agg_image_filters.o
agg_line_aa_basics.cpp -o agg_line_aa_basics.o
agg_line_profile_aa.cpp -o agg_line_profile_aa.o
agg_rounded_rect.cpp -o agg_rounded_rect.o
agg_sqrt_tables.cpp -o agg_sqrt_tables.o
agg_embedded_raster_fonts.cpp -o agg_embedded_raster_fonts.o
agg_trans_affine.cpp -o agg_trans_affine.o
agg_trans_warp_magnifier.cpp -o agg_trans_warp_magnifier.o
agg_trans_single_path.cpp -o agg_trans_single_path.o
agg_trans_double_path.cpp -o agg_trans_double_path.o
agg_vpgen_clip_polygon.cpp -o agg_vpgen_clip_polygon.o
agg_vpgen_clip_polyline.cpp -o agg_vpgen_clip_polyline.o
agg_vpgen_segmentator.cpp -o agg_vpgen_segmentator.o
ctrl/agg_cbox_ctrl.cpp -o ctrl/agg_cbox_ctrl.o
ctrl/agg_gamma_ctrl.cpp -o ctrl/agg_gamma_ctrl.o
ctrl/agg_gamma_spline.cpp -o ctrl/agg_gamma_spline.o
ctrl/agg_rbox_ctrl.cpp -o ctrl/agg_rbox_ctrl.o
ctrl/agg_slider_ctrl.cpp -o ctrl/agg_slider_ctrl.o
ctrl/agg_spline_ctrl.cpp -o ctrl/agg_spline_ctrl.o
ctrl/agg_scale_ctrl.cpp -o ctrl/agg_scale_ctrl.o
ctrl/agg_polygon_ctrl.cpp -o ctrl/agg_polygon_ctrl.o
ctrl/agg_bezier_ctrl.cpp -o ctrl/agg_bezier_ctrl.o
gcc -c -O3 -I/usr/openwin/include -L/usr/openwin/lib -I../include -L./
../gpc/gpc.c -o ../gpc/gpc.o
g++ -xar -o libagg.a agg_arc.o agg_arrowhead.o agg_bezier_arc.o
agg_bspline.o agg_curves.o agg_vcgen_contour.o agg_vcgen_dash.o
agg_vcgen_markers_term.o agg_vcgen_smooth_poly1.o agg_vcgen_stroke.o
agg_vcgen_bspline.o agg_gsv_text.o agg_image_filters.o
agg_line_aa_basics.o agg_line_profile_aa.o agg_rounded_rect.o
agg_sqrt_tables.o agg_embedded_raster_fonts.o agg_trans_affine.o
agg_trans_warp_magnifier.o agg_trans_single_path.o
agg_trans_double_path.o agg_vpgen_clip_polygon.o
agg_vpgen_clip_polyline.o agg_vpgen_segmentator.o ctrl/agg_cbox_ctrl.o
ctrl/agg_gamma_ctrl.o ctrl/agg_gamma_spline.o ctrl/agg_rbox_ctrl.o
ctrl/agg_slider_ctrl.o ctrl/agg_spline_ctrl.o ctrl/agg_scale_ctrl.o
ctrl/agg_polygon_ctrl.o ctrl/agg_bezier_ctrl.o ../gpc/gpc.o
g++: language ar not recognized
/usr/local/lib/gcc/i386-pc-solaris2.10/3.4.6/crt1.o: In function
`_start':
crt1.s:(.text+0x5c): undefined reference to `main'
collect2: ld returned 1 exit status
make[1]: *** [all] Error 1
make[1]: Leaving directory `/usr/local/agg-2.4/src'
make: *** [src/libagg.a] Error 2
Any thoughts, anyone? Thanks.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Associate Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
Sent: Tuesday, October 16, 2007 9:45 PM
To: Nolte, Tim
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Solaris AGG Compile...
The sunfreeware gcc package is compiled with --with-ld=/usr/ccs/bin/ld
so it can be hard to get around it. (you can see this by running g++ -v)
The sun ld version did not want to compile agg for me. I ended up
renaming /usr/ccs/bin/ld to /usr/ccs/bin/ld-off I then put it back
after the compile. This of course requires root access.
It is not very elegant but it worked. If anyone has any other
suggestions I'd love to know how to force the proper ld with resorting
to this. It just plain ignored the makefile and environment settings.
-Trent
Nolte, Tim wrote:
> OK, well here's my setup. I have the following sunfreeware packages
> installed:
> gcc-3.4.6-sol10-x86-local
> make-3.81-sol10-x86-local
> automake-1.10-sol10-x86-local
> libtool-1.5.24-sol10-x86-local
> I've set my PATH environment to use '/usr/local/bin' before
> '/usr/ccs/bin'. And my g++/gcc/make/ar/ld are all GNU when I run
'type'
> on them. I did notice that gcc reports (Configured with: ../configure
> --with-as=/usr/ccs/bin/as --with-ld=/usr/ccs/bin/ld --enable-shared
> --enable-languages=c,c++,f77) so I'm not sure if this would be an
issue.
> Thanks for any other thoughts.
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
