wfs geometry property element order
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Oct 18 10:45:57 EDT 2007
Mind you this was just a quick thought, but I was thinking of being
rather explicit:
gmp_property_order "delimited list of properties"
thus avoiding having to parse a schema. If that metadata tag isn't set
then data
order prevails.
Steve
>>> "Rushforth, Peter" <prushfor at NRCan.gc.ca> 10/17/07 3:11 PM >>>
Hi Steve,
So what values might gml_property_order have? A value to
indicate as layed out according to metadata (suggest "metadata")
and a value to indicate as layed according to as found in the data
(suggest "data"), are there any other possibilities?
Cheers,
Peter
> -----Original Message-----
> From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
> Sent: October 17, 2007 15:17
> To: MAPSERVER-USERS at LISTS.UMN.EDU; Rushforth, Peter
> Subject: Re: [UMN_MAPSERVER-USERS] wfs geometry property element order
> We could consider an gml_property_order transformation? If
> not set then the current ordering would be maintained.
> Steve
> >>> "Rushforth, Peter" <prushfor at NRCAN.GC.CA> 10/17/07 11:21 AM >>>
> Hi Tom,
> Thanks for the response.
> Some of the CGDI interoperability pilot project participants
> are using MapServer.
> We established an application schema based on the geobase.ca
> RoadSegment content model, which uses an xsd:sequence of
> property elements.
> Cheers,
> Peter
> > From: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Kralidis,Tom
> > [Burlington]
> > Sent: October 17, 2007 12:00
> element order
> > Peter,
> > Not that I know of. You could (could) run the process
> through a WxS
> > process, but that would be a bit of work. Or you could try
> > re-ordering your application schema's elements.
> > Out of interest. why did you want to do this? To adhere to an app
> > schema?
> > ..Tom
> > ________________________________
> > From: UMN MapServer Users List on behalf of Rushforth, Peter
> > Sent: Wed 17-Oct-07 10:05
> > Subject: [UMN_MAPSERVER-USERS] wfs geometry property element order
> > Hi,
> > We are trying to follow an application schema with the
> mapserver wfs
> > component. Our source is shapefiles. We can re-order property
> > elements simply by reordering the columns in the shapefile, but
> > because the SHAPE column is always first in the shapefile, we can't
> > re-order the geometry property to where we want it according to the
> > schema. Is there a workaround for this problem?
> > Thanks,
> > Peter Rushforth
> > Technology Advisor / Conseiller technique GeoConnections /
> > GéoConnexions
> > 650-615 Booth St. / rue Booth
> > Ottawa ON K1A 0E9
> > E-mail / Courriel: Peter.Rushforth at NRCan.gc.ca Phone /
> > Télephone: (613) 943-0784 Fax / telecopier: (613) 947-2410
