Mapfile PROJECTION questions
gwaldron gwaldron at GMAIL.COM
Thu Oct 18 11:38:22 EDT 2007
Hi, a couple (hopefully) easy questions about the PROJECTION directive in the
.map file:
First: I have shapefiles with .prj projection information, in WKT format.
How can I represent that in the .map file? I do not see a way to put a WKT
string in the PROJECTION block. (Background: I am trying to automatically
generate .map files so manually converting WKT to PROJ4 strings is not
really an option.)
Second: How does the PROJECTION AUTO option work? I tried using this at the
LAYER level, but it does not seem to work (i.e. the WFS feed gives me an
error about not including a required PROJECTION block).
I'm using MS4W 2.2.6 (mapserver 5.0). Thanks in advance.
View this message in context: http://www.nabble.com/Mapfile-PROJECTION-questions-tf4647894.html#a13277353
Sent from the Mapserver - User mailing list archive at Nabble.com.
