mapscript point layer zooming
Tamas Szekeres szekerest at GMAIL.COM
Fri Oct 19 11:10:49 EDT 2007
Hi Fanda,
This is due to a problem around the mapserver shape file driver. I've
submitted a ticket with this issue:
http://trac.osgeo.org/mapserver/ticket/2354
Until the fix is applied you might want to use the OGR driver instead
which is working properly. All you have to do is to replace the DATA
section with
CONNECTIONTYPE OGR
CONNECTION "vrty.shp"
in your layer definition in the mapfile.
Best regards,
Tamas
2007/10/19, Fanda <zerosgm at gmail.com>:
> Hi Tamas,
> I've tried to render the map with drawmap but it behaves exactly the same as
> my app. I submit all the needed data with this message. I put both the
> extents (full view and zoomed view when the layer 'vrty' doesn't show up) in
> the mapfile definition.
> Best regards,
> Fanda
> Tamas Szekeres wrote:
> > Hi,
> > You might want to test with the drawmap C# sample (can be found in the
> > ms4w package as well) to see whether the application can draw the
> > layer with the same extent. (set the extent of the map in the mapfile
> > accordingly).
> > If drawmap behaves the same, then submit a ticket with your data file
> > along with the mapfile for tracking down the problem.
> > Best regards,
> > Tamas
> > 2007/10/17, Fanda <zerosgm at gmail.com>:
> >> I am using the latest version of mapserver (ms4w 2.2.6), c# mapscript. I
> >> don't know exactly what inline layer means, but I don't think that's the
> >> case of my layer. I've attached the whole mapfile to this message (the
> >> point
> >> layer is the very last one called 'Vrty'). It shows up in full extent,
> >> but
> >> as I pan or zoom so that any point of the layer is outside the current
> >> extent, the whole layer disappears.
> >> Best regards,
> >> Fanda
> >> > Hi,
> >> > It would be helpful to post the entire mapfile you have. Are you using
> >> > an inline layer as the point layer?
> >> > Which projection you use with your map? What is the mapserver version?
> >> > Best regards,
> >> > Tamas
> >> > 2007/10/16, Fanda <zerosgm at gmail.com>:
> >> >> Hi all,
> >> >> I am facing really odd problem. I have some line and polygon layers in
> >> my
> >> >> mapfile and everything goes fine with them. But there is also one
> >> POINT
> >> >> layer and it shows up only in its full extent. If I zoom in or pan the
> >> >> layer
> >> >> disappears whereas the other layers are still visible as expected.
> >> There
> >> >> is
> >> >> no max/minscale defined. I am using C# mapscript. The definition of
> >> the
> >> >> layer in the mapfile is as follows:
> >> >>   LAYER
> >> >>     NAME                Vrty
> >> >>     STATUS      ON
> >> >>     TYPE                POINT
> >> >>     DATA                "vrty"
> >> >>     TOLERANCE   1
> >> >>     CLASS
> >> >>       NAME                      'vrty'
> >> >>       STYLE
> >> >>         SYMBOL          'circle'
> >> >>         SIZE            20
> >> >>         COLOR           255 0 0
> >> >>       END
> >> >>     END
> >> >>     PROJECTION
> >> >>       "init=epsg:2065"
> >> >>     END
> >> >>   END
> >> >> Any help would be greatly appreciated,
> >> >> Fanda
> >> >> View this message in context:
> >> http://www.nabble.com/mapscript-point-layer-zooming-tf4632685.html#a13229010
> >> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
> >> http://www.nabble.com/file/p13247791/mapa.map mapa.map
> >> http://www.nabble.com/mapscript-point-layer-zooming-tf4632685.html#a13247791
> http://www.nabble.com/file/p13289551/data.zip data.zip
> View this message in context: http://www.nabble.com/mapscript-point-layer-zooming-tf4632685.html#a13289551
