MS 5.x URL substitution changes - FILTER?
Randy How
rhow at I3.COM
Mon Oct 22 10:09:08 EDT 2007
I'm stumped again. For 5.x it's noted in the migration guide the CGI URL
substitutions have changed:
http://trac.osgeo.org/mapserver/browser/tags/rel-5-0-0/mapserver/MIGRATION_G
UIDE.TXT
It's the FILTER I need to override on the layer in the map file. I'm
wondering if it's even possible anymore, or is there some other method to
achieve the same thing.
Thanks, Randy
. Works on MapServer 4.99:
http://localhost/datadoorswebserver_25/mapserver/mapserv.exe?map=C:\_repos\.
..\product_coverage.map&mode=map&map_product_filter=product_id%3D7
. My best attempt which fails (miserably) on 5.1:
http://localhost/DataDoorsWebServer/mapserver/mapserv.exe?
map=C:\_repos\...
\product_coverage.map&map.layer[product]=FILTER+product_id%3D7
Error: loadLayer(): Unknown identifier. Parsing error near (FILTER):(line 1)
Also tried: .&map.layer[product].FILTER=product_id%3D7
(product_id=7):(line 1)
. For grins I got this to work, with the FILTER commented-out in the
map file:
http://localhost/DataDoorsWebServer/mapserver/mapserv.exe?map=C:\_repos\...\
product_coverage.map&map.layer[product].class[0].style[0]=OUTLINECOLOR+255+2
55+0
. Below is the map layer:
LAYER
NAME "product"
CONNECTIONTYPE postgis
CONNECTION "user=u password=p dbname=db host=x.x.x.x"
DATA "geometry from vw_product_coverage using unique geometry"
FILTER "product_id=0"
FILTERITEM "product_id"
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASS
STYLE
OUTLINECOLOR 255 0 0
SYMBOL 1
SIZE 3
END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071022/672cc4b1/attachment.html
