Displaying elevation data
Kyle Wilcox Kyle.Wilcox at NOAA.GOV
Mon Oct 22 10:11:44 EDT 2007
I'm not sure if this will help you, but here is an example GeoTIFF file
with an associated data file.  Depending on how you set up the
application, you should be able to query just the data layer.
Application is here to try it out:  http://155.206.18.162/SST/
LAYER
    NAME DailyData
    STATUS ON
    DATA "daily.flt"
    TYPE RASTER
    METADATA
        "DESCRIPTION" "Daily SST"
        "RESULT_FIELDS" "Lat Lon SST(C)"
        "VALUE_FIELDS" "x y value_0"
    END
    PROJECTION
      "proj=merc"
      "ellps=WGS84"
      "datum=WGS84"
    END
    UNITS METERS
    SIZEUNITS PIXELS
    TOLERANCEUNITS PIXELS
    PROCESSING "SCALE=2,15"
    TEMPLATE "placeholder"
  END
  LAYER
    NAME DailyColors
    STATUS ON
    DATA "daily.tif"
    TYPE RASTER
    METADATA
        "DESCRIPTION" "Daily RGB Values"
    END
    PROJECTION
      "proj=merc"
      "ellps=WGS84"
      "datum=WGS84"
    END
    UNITS METERS
    SIZEUNITS PIXELS
    PROCESSING "BANDS=1,2,3"
  END
Vishal Nagpal wrote:
> Thanks for quick response,
> I did see the images of terrain data on the mentioned url, they are
> interesting and suit my requirement, i will certainly explore more of it,
> Is it possible to keep the display in 2D itself but use dt1 files for query
> in mapserver,
> how to i know elevation at a certain point even if i don't get the display.
> the application i am developing is in its initial stages,
> do i shift to grass or continue using both.
 Kyle Wilcox
 NOAA Chesapeake Bay Office
 410 Severn Avenue
 Suite 107A
 Annapolis, MD 21403
 office: (410) 295-3151
 Kyle.Wilcox at noaa.gov
 "It is from the wellspring of our despair and the places
  that we are broken that we come to repair the world."
						- Murray Waas
