Google Earth -Get capabilities error
Silvia Petcu silvia.petcu at DPRA.COM
Wed Oct 31 14:54:45 EDT 2007
I'm trying to add my wms layers to Google Earth and it is failing when I’m using
the GetCapabilities url in the “Web Mapping Service parameters” window (the
address is working fine in ArcCatalog or IE). The error says that this WMS
service has no layers that can be rendered by Google Earth.
http://ntgomap.nwtgeoscience.ca/cgi-bin/wms_test.php?
VERSION=1.1.1&request=Getcapabilities&service=wms&srs=EPSG:4326
I can add individual WMS layers by entering the “GetMap” url in the Link
textbox from the same map file that is failing on GetCapabilities.
VERSION=1.1.1&request=GetMap&srs=EPSG:4326&BBOX=-146.4,52.15,-
93.6,97.74&WIDTH=500&HEIGHT=500&LAYERS=ArcheanLimits&STYLES=&FORM
AT=image/png
Bellow is the map file that has this behavior. I need to know what do I have to
do as Google map to be able to get handle the GetCapabilities url as well.
MAP
  DEBUG OFF
  NAME "NTGO_Portal_WMS"
  STATUS ON
  EXTENT -146.4 52.161287067696 -93.6 97.7368329192244
  SIZE 684 561
  SHAPEPATH "D:\Gomap_data\Export"
  SYMBOLSET "GeoPortal.symbols"
  FONTSET "GeoPortal.fonts"
  TRANSPARENT ON
  UNITS dd
  IMAGETYPE PNG24
  OUTPUTFORMAT
    NAME PNG24
    DRIVER "GD/PNG"
    MIMETYPE "image/png"
    IMAGEMODE RGBA
    EXTENSION PNG
    TRANSPARENT ON
    FORMATOPTION "INTERLACE=NO"
  END
  WEB
    MAXSCALE 40000000
    MINSCALE 100
    IMAGEPATH "C:\Inetpub\wwwroot\tmp\"
    IMAGEURL "/tmp/"
    LOG /tmp/log/MS_ERRORS.LOG
    HEADER "templates/header.html"
    FOOTER "templates/footer.html"
    TEMPLATE "set in index.html"
    METADATA
     WMS_ONLINERESOURCE 'http://ntgomap.nwtgeoscience.ca/cgi-
bin/wms_test.php?'
     WMS_SRS 'epsg:4326'
     WMS_ACCESSCONSTRAINTS 'none'
     WMS_TITLE 'NTGO Web GIS Portal'
     WMS_FEATURE_INFO_MIME_TYPE 'text/html'
     WMS_ABSTRACT 'This Web Map Service broadcasts metadata '
    END  #METADATA
  END #WEB
  PROJECTION
    "init=epsg:4326" #unprojected lat long
  END
LAYER
  NAME 'NTGOSurvey'
  DATA '4326Geoch_Geoph_Survey'
  STATUS on
  DUMP true # VERY IMPORTANT atribute
  TYPE Polygon
  TRANSPARENCY 100
  TOLERANCE 10
  TOLERANCEUNITS pixels
  TEMPLATE "null"
  METADATA
   WMS_SRS  'epsg:4326'
   WMS_TITLE 'NTGOSurvey'
   gml_include_items "all"
   gml_exclude_items "geometry"
  END #METADATA
  PROJECTION
  'init=epsg:4326'
  END
  CLASS
   NAME 'Geoch/Geoph Survey'
   STYLE
    COLOR 255 0 0
       OUTLINECOLOR 0 0 0
   END #STYLE
  END #CLASS
 END #LAYER
LAYER
 NAME 'ArcheanLimits'
  DATA '4326Archean_Limits_lambert'
  STATUS on
  TYPE Polygon
  TRANSPARENCY 100
  TOLERANCE 10
  TEMPLATE "null"
  METADATA
   WMS_SRS  'epsg:4326'
   WMS_TITLE 'ArcheanLimits'
  END #METADATA
  PROJECTION
  'init=epsg:4326'
  END
 CLASS
  STYLE
   SYMBOL "line"
   SIZE 3
    OUTLINECOLOR 254 172 0
  END #STYLE
 END #CLASS
END #LAYER
END #End of Mapfile
I appreciate any kind of help that will bring some light to my problem.
Silvia Petcu
DPRA Inc.
