MapScripting on ASP pages
Tamas Szekeres
szekerest at GMAIL.COM
Wed Sep 12 05:17:39 EDT 2007
Those files can be found in the /mapscript/csharp directory of the
mapserver source tree. The current release can be downloaded from
here:
http://download.osgeo.org/mapserver/mapserver-4.10.3.tar.gz
In your application add a reference to the mapscript_csharp.dll and
ensure that all of the dependent dll-s are available in the PATH.
Most of the binary distributions like ms4w and FWTools should contain
all the dll-s required.
Best regards,
Tamas
2007/9/12, Hayden Fisher <support at bizeasset.com.au>:
> Hi Howard,
> Yeah I was just thinking the same thing! Where would I find the source
> for the C# MapScript?
> Regards,
> Hayden Fisher
> -----Original Message-----
> From: Howard Butler [mailto:hobu.inc at gmail.com]
> Sent: Wednesday, 12 September 2007 12:18 PM
> To: Hayden Fisher
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: MapScripting on ASP pages
> Do you mean old-school VB6? no. You could use the .NET/C# bindings
> with ASP.NET though.
> Howard
> On Sep 11, 2007, at 8:42 PM, Hayden Fisher wrote:
> > Hi All,
> > Have basically just started with MapServer, MapScript etc. My
> > situation is that I'd like to build a mapping application into some
> > ASP pages, e.g. VB.
> > However the examples I've come across are all for either PERL,
> > PYTHON and PHP.
> > (These existing pages are already querying out a lot of attribute
> > information from MapInfo tables so there's not too much chance of
> > changing languages, hence the following questions)
> > Is there a VB version out there? If so where could I find a copy?
> > If not is there still a way to build an application into the *.asp
> > pages using the above languages?
> > Any advice would be great on where to start.
> > Regards,
> > Hayden Fisher
> > Development and Support
> > BizeAsset Pty Ltd
> > Mob: (04) 3838 4747
> > Ph: (07) 3369 2222
> > Fax: (07) 3369 8883
> > Toll Free: 1800 836 850
