MapServer 5.0.0 released!
Nolte, Tim
Tim.Nolte at IPCSWIRELESSINC.COM
Wed Sep 19 16:01:51 EDT 2007
Thomas,
You've totally made my day. I was finally able to get your patch applied
today. I tested it out and it works wonderfully. My mapfile went from a
whopping 17sec down to a little over 5sec. I don't know if this feature
would ever actually make it into the full release but it's a keeper as
far as I'm concerned.
Timothy J Nolte - tnolte at ilpcs.com
Associate Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Tuesday, September 18, 2007 1:46 PM
To: Nolte, Tim
Cc: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] MapServer 5.0.0 released!
On 9/18/07, Nolte, Tim <Tim.Nolte at ipcswirelessinc.com> wrote:
> Thomas,
> I'll give this a try, and see what I get. Thanks. I'll let you how it
> works. Just so I get this straight I add "ANTIALIAS FALSE" to my
layer
> after the patch and that layer won't be antialiased, correct?
nope, that's not it..
you create the symbol definition in your symbol file or inlined in
your mapfile. and then you set the layers you want rendered fast to
LAYER
NAME blablba
DATA ...
CLASS
STYLE
COLOR r g b
SYMBOL 'aliased'
END
END
END
it's slower than gd but did speed up dense line drawings by a factor
of 3 when i tried it, less with polygons.
tb
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
> Sent: Tuesday, September 18, 2007 12:31 PM
> To: Nolte, Tim
> Tim,
> Attached is a patch you can apply to mapagg.cpp - if you can't apply
> it I'll mail you the whole file.
> it basically switches to aliased rendering if you use
> SYMBOL
> TYPE SIMPLE
> ANTIALIASED FALSE
> NAME 'aliased'
> END
> it'll work *only* on line and polygon layers, if you specify a
> STYLE
> NAME 'aliased'
> COLOR r g b
> END
> nothing other is supported (line widths, or polygon outlines)
> I'd be interested to hear about timings if you can try it
> tb
