mapserver 4.10.2 and debug informations
Daniel Morissette
dmorissette at MAPGEARS.COM
Mon Feb 4 10:01:43 EST 2008
With MapServer 4.x, LOG is only used to log errors (as you noticed) and
all DEBUG output goes to stderr, in the case of Apache that is Apache's
error_log file. Note that you can also set DEBUG ON at the layer level
to get more debug info for specific layers.
Starting with MapServer 5.0, the DEBUG output location is controlled by
the CONFIG "MS_ERRORFILE" "/path/to/logfile" directive, and support for
multiple debug levels has been added. More info is available in RFC-28:
http://mapserver.gis.umn.edu/development/rfc/ms-rfc-28
Daniel
patrice canonici wrote:
> Hi
> I'm trying to have lots of debug information into log file.
> In the mapfile there is :
> MAP bloc : DEBUG ON
> WEB bloc : LOG "/tmp/mapserver.log"
> in many LAYER bloc DEBUG ON
> mapserver is configure as follow :
> ./mapserv -vMapServer version 4.10.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> DEBUG=MSDEBUG
> mapserver is running into apache httpd 2.0.59 (compiled, not from rpm)
> on Red Hat Linux.
> /tmp/mapserver.log remains empty, and I get only "error" (that seems
> not to be errors) level message into the httpd error_log file.
> is it possible to have these informations into the mapserver log file
> ? (/tmp/mapserver.log). ? if yes, how ?
> and, is it possible to have a more verbose log ? with debug/warn/...
> informations ?
> Regards
> Patrice
Daniel Morissette
http://www.mapgears.com/
