projection EPSG:4362 vs EPSG:29882
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Fri Jan 11 07:16:52 EST 2008
If I look at your request, do I see &SRS=EPSG:4326 Is that corrert or typo?
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: UMN MapServer Users List puolesta: Peter Peterse
Lähetetty: pe 11.1.2008 13:55
Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: [UMN_MAPSERVER-USERS] projection EPSG:4362 vs EPSG:29882
Hello all,
I'm having problems with the projection
<http://tol.han-dataport.nl/cgi-bin/mapserv?map=/data/osm.map&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:4326&WIDTH=500&HEIGHT=500&LAYERS=Wegen,Grens&STYLES=&TRANSPARENT=TRUE&FORMAT=image/png&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=4.2885413646778385,52.25793323942671,5.761033023649884,53.161245776968755>
and
<http://tol.han-dataport.nl/cgi-bin/mapserv?map=/data/osm.map&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:28992&WIDTH=500&HEIGHT=500&LAYERS=Wegen,Grens&STYLES=&TRANSPARENT=TRUE&FORMAT=image/png&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=80000,475000,180000,575000>
The coördinates should be the same. The bbox is an rect from 100 by 100 km
EPSG:4362 gives only a differend scalebar (150km)
I'v attached my map file (osm.map) with this message
Can anyone give me a clue whats going false?
regards,
Peter
