projection EPSG:4362 vs EPSG:29882
Peter Peterse
peter at PETERSE-UITHUIZEN.COM
Fri Jan 11 07:22:54 EST 2008
Oeps. EPSG:4326 is correct the typo is EPSG:4362
> Hi,
> If I look at your request, do I see &SRS=EPSG:4326 Is that corrert or
> typo?
> -Jukka-
> -----Alkuperäinen viesti-----
> Lähettäjä: UMN MapServer Users List puolesta: Peter Peterse
> Lähetetty: pe 11.1.2008 13:55
> Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
> Aihe: [UMN_MAPSERVER-USERS] projection EPSG:4362 vs EPSG:29882
> Hello all,
> I'm having problems with the projection
> <http://tol.han-dataport.nl/cgi-bin/mapserv?map=/data/osm.map&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:4326&WIDTH=500&HEIGHT=500&LAYERS=Wegen,Grens&STYLES=&TRANSPARENT=TRUE&FORMAT=image/png&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=4.2885413646778385,52.25793323942671,5.761033023649884,53.161245776968755>
> and
> <http://tol.han-dataport.nl/cgi-bin/mapserv?map=/data/osm.map&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:28992&WIDTH=500&HEIGHT=500&LAYERS=Wegen,Grens&STYLES=&TRANSPARENT=TRUE&FORMAT=image/png&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=80000,475000,180000,575000>
> The coördinates should be the same. The bbox is an rect from 100 by 100 km
> EPSG:4362 gives only a differend scalebar (150km)
> I'v attached my map file (osm.map) with this message
> Can anyone give me a clue whats going false?
> regards,
> Peter
