Please help me SDE C# asp.net and mapserver connection
problem....
yatendra
yatendra.jaiswal at GMAIL.COM
Fri Jan 18 04:28:41 EST 2008
Here is my mapfile layer....
LAYER
CONNECTION "host=GEN387 port:5151 user=****** password=****** dbname=****"
CONNECTIONTYPE SDE
CONNECTIONTYPE PLUGIN
PLUGIN "C:\ms4w\Apache\specialplugins\msplugin_sde_92.dll"
DATA "sde.SDE.TILE,SHAPE,sde.DEFAULT"
STATUS on
TYPE line
END
If its because of asp.net version (64 bit), then what can be the solution???
please let me know..
Thanks Regards
Tamas Szekeres wrote:
> Yatendra,
> It seems the ASP runtime is not able to load the plugin dll. You might
> want try to copy this dll into the same directory where your ASP.NET
> host process is running. If the dll can be loaded from the same
> directory then it might be a security related issue.
> Another problem is that the SDE plugin is compiled as a 32 bit image
> and the 64 bit version of the .NET framework cannot load it,
> definitely.
> Best regards,
> Tamas
> 2008/1/15, yatendra <yatendra.jaiswal at gmail.com>:
>> Hi to all,
>> I am trying to connect mapserver with SDE.
>> I have successfully connected in html(Map file working fine).
>> Now i am trying this asp.net connetion with same map file.
>> i followed all instruction and source codes given in tutorial
>> http://www.paolocorti.net/public/wordpress/index.php/2006/09/20/mapserver-tutorial-for-c-mapscript-asp-net/.
>> application is giving error while running. and error is as follows in
>> MapStream.aspx.cs
>> msDrawMap(): Image handling error. Failed to draw layer named
>> 'TILE'.;loadCustomLayerDLL: General error message. Failed to load dynamic
>> Layer LIB:
>> C:\ms4w\Apache\specialplugins\msplugin_sde_92.dll;msGetSymbol(): General
>> error message. Can't load requested dynamic library:
>> PLease help me out to solve this problem.
>> Why i am getting this problem.
>> Can anyone explain please…
>> Thanks Regards
>> Yatendra
>> View this message in context:
>> http://www.nabble.com/Please-help-me-SDE-C--asp.net-and-mapserver-connection-problem....-tp14749790p14749790.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/Please-help-me-SDE-C--asp.net-and-mapserver-connection-problem....-tp14749790p14948034.html
