Segfaults with Mapserver 5.0.0
Rodrigo Del C. Andrade
rodrigo.andrade at DIGITRO.COM.BR
Fri Jan 18 08:07:19 EST 2008
Good morning all.
I am running tests on Mapserver 5 to test its viability on our
production enviroment and I have run into some problems I am having
trouble to figure out.
A little background, may be irrelevant, but could be useful, idk:
- We have a stand alone java server application (doing the map work
with Java Mapscript) which talks via RMI with the client part of the
app, which is running on Tomcat. We've done it this way because past
crashes on mapserver used to bring Tomcat down with it
- This mapscript binary was compiled with all the latest stable
versions of GDAL, GEOS, Proj, AGG, LibPNG, GD and Freetype.
- We are outputting the final map images with AGG.
- The source data lives in Shape files. All of them have indexes,
and I broke large areas into smaller chunks and tile indexed them with
tile4ms.
Now, this one is the first of the the 2 different segfaults I am
experiencing with 5.0, but decided to focus on this one first because it
seems to happen more frequently. Whenever I am zooming in or out in the
map, this bugger seems to happen at random. I was'nt able to pin point a
pattern for it to happen, looks like just using it long enough will do it.
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0x00734600, pid=30922, tid=1812704176
# Java VM: Java HotSpot(TM) Server VM (1.5.0_07-b03 mixed mode)
# Problematic frame:
# C [libc.so.6+0x69600] strncpy+0x30
I am not any C buff by any means, but judging from a strncpy error,
I assume something in the way strings are created/handled might have
changed since 4.x (I haven't been following the list recently, forgive
me if it's old news)
Any ideas about what might be causing it?
-- Full log is bellow the sig.
Thanks!
*Rodrigo Del C. Andrade*
/Programador/
/SIC - SSE - Soluções Segurança Pública/
*DÍGITRO TECNOLOGIA*
*E-mail:* rodrigo.andrade at digitro.com.br
<mailto:rodrigo.andrade at digitro.com.br>
*Fone:* +55 48 3281-7314 / +55 48 3281-7000
*Fax:* +55 48 3281-7299
*Site:* www.digitro.com <http://www.digitro.com>
--------------- T H R E A D ---------------
Current thread (0x08277378): JavaThread "RMI TCP
Connection(4)-192.168.167.93" daemon [_thread_in_native, id=30972]
siginfo:si_signo=11, si_errno=0, si_code=2, si_addr=0x690ffd86
Registers:
EAX=0x69300470, EBX=0x6cd77da8, ECX=0x690ffd86, EDX=0x6930046f
ESP=0x6c0b6cbc, EBP=0x6c0b6ccc, ESI=0x00001252, EDI=0x00004949
EIP=0x00734600, CR2=0x690ffd86, EFLAGS=0x00010202
Top of Stack: (sp=0x6c0b6cbc)
0x6c0b6cbc: fffffff0 69300470 690f9a48 690ffd86
0x6c0b6ccc: 6c0b6cfc 6cc9e32f 69300470 690ffd86
0x6c0b6cdc: 00004949 0000494a 690f59c8 69300470
0x6c0b6cec: 00000173 6cd77da8 00000001 694bea30
0x6c0b6cfc: 6c0b6d2c 6cc9eb3a 00000003 00000021
0x6c0b6d0c: 00000003 00000000 690f93b0 8d347372
0x6c0b6d1c: c04a3e75 6cd77da8 00000021 092a5cb8
0x6c0b6d2c: 6c0b75fc 6cc9c74d 690f9a48 00000021
Instructions: (pc=0x00734600)
0x007345f0: 02 eb 0d 90 90 90 90 90 90 90 90 90 90 90 90 90
0x00734600: 0f b6 01 42 84 c0 88 02 74 67 0f b6 41 01 42 84
Stack: [0x6c03a000,0x6c0bb000), sp=0x6c0b6cbc, free space=499k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code,
C=native code)
C [libmapscript.so+0x6832f]
C [libmapscript.so+0x68b3a] msDBFGetValueList+0x52
C [libmapscript.so+0x6674d] msTiledSHPNextShape+0x30d
C [libmapscript.so+0x918d2] msLayerNextShape+0x3e
C [libmapscript.so+0x9d112] msDrawVectorLayer+0x2be
C [libmapscript.so+0x9d3f9] msDrawLayer+0xb5
C [libmapscript.so+0x9e154] msDrawMap+0x1dc
C [libmapscript.so+0x45f2e]
Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1draw+0x36
j edu.umn.gis.mapscript.mapscriptJNI.mapObj_draw(J)J+0
j edu.umn.gis.mapscript.mapObj.draw()Ledu/umn/gis/mapscript/imageObj;+4
j
br.com.digitro.idseg.gis.model.IDSegGisMapFactory.drawMap(Ledu/umn/gis/mapscript/mapObj;Ljava/io/File;Ljava/io/File;)V+6
j
br.com.digitro.idseg.gis.model.IDSegGisMapFactory.createMapa(Ledu/umn/gis/mapscript/mapObj;Ljava/util/Map;Ljava/util/List;Ljava/lang/String;Ljava/lang/String;Ljava/util/Map;Ljava/util/List;Ljava/lang/String;Ljava/lang/String;)Lbr/com/digitro/idseg/gis/pojo/MapaVO;+2041
j
br.com.digitro.idseg.gis.rmi.GisImpl.createMapa(Ljava/lang/String;Ljava/util/Map;Ljava/util/List;Ljava/lang/String;Ljava/lang/String;Ljava/util/Map;Ljava/io/File;ZLjava/util/List;Ljava/lang/String;Ljava/lang/String;)Lbr/com/digitro/idseg/gis/pojo/MapaVO;+56
j
sun.reflect.GeneratedMethodAccessor3.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+143
j
sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j
java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+111
j
sun.rmi.server.UnicastServerRef.dispatch(Ljava/rmi/Remote;Ljava/rmi/server/RemoteCall;)V+246
j sun.rmi.transport.Transport$1.run()Ljava/lang/Object;+23
v ~StubRoutines::call_stub
V [libjvm.so+0x2649ac]
V [libjvm.so+0x427bc8]
V [libjvm.so+0x2647df]
V [libjvm.so+0x2c1efd]
C [libjava.so+0x93bc]
Java_java_security_AccessController_doPrivileged__Ljava_security_PrivilegedExceptionAction_2Ljava_security_AccessControlContext_2+0x3c
j
java.security.AccessController.doPrivileged(Ljava/security/PrivilegedExceptionAction;Ljava/security/AccessControlContext;)Ljava/lang/Object;+0
j
sun.rmi.transport.Transport.serviceCall(Ljava/rmi/server/RemoteCall;)Z+163
j
sun.rmi.transport.tcp.TCPTransport.handleMessages(Lsun/rmi/transport/Connection;Z)V+185
j sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run()V+685
j java.lang.Thread.run()V+11
V [libjvm.so+0x264205]
V [libjvm.so+0x26429e]
V [libjvm.so+0x2db925]
V [libjvm.so+0x4c6cb3]
V [libjvm.so+0x4287d8]
C [libpthread.so.0+0x5371]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j
j
j
j
j
j
j
j
j
j
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x6a9e4068 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=31039]
=>0x08277378 JavaThread "RMI TCP Connection(4)-192.168.167.93" daemon
0x0805d2c0 JavaThread "DestroyJavaVM" [_thread_blocked, id=30922]
0x08125060 JavaThread "RMI LeaseChecker" daemon [_thread_blocked,
id=30944]
0x6cf3a1f0 JavaThread "RMI RenewClean-[192.168.167.93:31548]" daemon
[_thread_blocked, id=30942]
0x08285f68 JavaThread "RMI TCP Accept-1097" daemon [_thread_in_native,
id=30940]
0x6cf03650 JavaThread "GC Daemon" daemon [_thread_blocked, id=30939]
0x6cf07e98 JavaThread "RMI Reaper" [_thread_blocked, id=30938]
0x6cf07910 JavaThread "Timer-0" daemon [_thread_blocked, id=30937]
0x6cf08338 JavaThread "RMI TCP Accept-0" daemon [_thread_in_native,
id=30936]
0x08121290 JavaThread "Low Memory Detector" daemon [_thread_blocked,
id=30934]
0x0811fdc0 JavaThread "CompilerThread1" daemon [_thread_blocked, id=30933]
0x0811ed18 JavaThread "CompilerThread0" daemon [_thread_blocked, id=30932]
0x0811dba0 JavaThread "AdapterThread" daemon [_thread_blocked, id=30931]
0x0811ccb8 JavaThread "Signal Dispatcher" daemon [_thread_blocked,
id=30930]
0x081126b8 JavaThread "Finalizer" daemon [_thread_blocked, id=30929]
0x08112158 JavaThread "Reference Handler" daemon [_thread_blocked,
id=30928]
Other Threads:
0x0810fc90 VMThread [id=30927]
0x08122778 WatcherThread [id=30935]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 11392K, used 797K [0xaa4e0000, 0xabb00000,
0xb1580000)
eden space 10560K, 4% used [0xaa4e0000,0xaa563668,0xaaf30000)
from space 832K, 32% used [0xaaf30000,0xaaf74000,0xab000000)
to space 768K, 0% used [0xaba40000,0xaba40000,0xabb00000)
PSOldGen total 57664K, used 1323K [0x71f80000, 0x757d0000,
0xaa4e0000)
object space 57664K, 2% used [0x71f80000,0x720caee0,0x757d0000)
PSPermGen total 16384K, used 6761K [0x6df80000, 0x6ef80000,
0x71f80000)
object space 16384K, 41% used [0x6df80000,0x6e61a410,0x6ef80000)
Dynamic libraries:
002e3000-00346000 r-xp 00000000 08:01 191558 /usr/lib/libkrb5.so.3.2
00346000-00348000 rwxp 00063000 08:01 191558 /usr/lib/libkrb5.so.3.2
0034a000-0037b000 r-xp 00000000 08:01 377252 /lib/libssl.so.0.9.7a
0037b000-0037e000 rwxp 00031000 08:01 377252 /lib/libssl.so.0.9.7a
004ca000-0058a000 r-xp 00000000 08:01 182584 /usr/lib/libstdc++.so.6.0.3
0058a000-0058f000 rwxp 000bf000 08:01 182584 /usr/lib/libstdc++.so.6.0.3
0058f000-00595000 rwxp 0058f000 00:00 0
005cd000-005ed000 r-xp 00000000 08:01 179178 /usr/lib/libk5crypto.so.3.0
005ed000-005ee000 rwxp 00020000 08:01 179178 /usr/lib/libk5crypto.so.3.0
00617000-00645000 r-xp 00000000 08:01 193564 /usr/lib/libidn.so.11.4.6
00645000-00647000 rwxp 0002d000 08:01 193564 /usr/lib/libidn.so.11.4.6
006ad000-006c2000 r-xp 00000000 08:01 376099 /lib/ld-2.3.4.so
006c2000-006c3000 r-xp 00015000 08:01 376099 /lib/ld-2.3.4.so
006c3000-006c4000 rwxp 00016000 08:01 376099 /lib/ld-2.3.4.so
006cb000-007f0000 r-xp 00000000 08:01 376100 /lib/tls/libc-2.3.4.so
007f0000-007f1000 r-xp 00124000 08:01 376100 /lib/tls/libc-2.3.4.so
007f1000-007f4000 rwxp 00125000 08:01 376100 /lib/tls/libc-2.3.4.so
007f4000-007f6000 rwxp 007f4000 00:00 0
007fe000-0081f000 r-xp 00000000 08:01 376101 /lib/tls/libm-2.3.4.so
0081f000-00821000 rwxp 00020000 08:01 376101 /lib/tls/libm-2.3.4.so
00914000-00922000 r-xp 00000000 08:01 376103
/lib/tls/libpthread-2.3.4.so
00922000-00924000 rwxp 0000d000 08:01 376103
00924000-00926000 rwxp 00924000 00:00 0
0094d000-0095c000 r-xp 00000000 08:01 193548 /usr/lib/libz.so.1.2.1.2
0095c000-0095d000 rwxp 0000e000 08:01 193548 /usr/lib/libz.so.1.2.1.2
00aee000-00b01000 r-xp 00000000 08:01 191887
/usr/lib/libgssapi_krb5.so.2.2
00b01000-00b02000 rwxp 00013000 08:01 191887
00b10000-00b2d000 r-xp 00000000 08:01 193558 /usr/lib/libexpat.so.0.5.0
00b2d000-00b2f000 rwxp 0001d000 08:01 193558 /usr/lib/libexpat.so.0.5.0
00bbe000-00bc5000 r-xp 00000000 08:01 374652
/lib/libgcc_s-3.4.6-20060404.so.1
00bc5000-00bc6000 rwxp 00007000 08:01 374652
00c1d000-00c2f000 r-xp 00000000 08:01 376111 /lib/libnsl-2.3.4.so
00c2f000-00c31000 rwxp 00011000 08:01 376111 /lib/libnsl-2.3.4.so
00c31000-00c33000 rwxp 00c31000 00:00 0
00c80000-00c82000 r-xp 00000000 08:01 376108 /lib/libcom_err.so.2.1
00c82000-00c83000 rwxp 00001000 08:01 376108 /lib/libcom_err.so.2.1
00d53000-00d55000 r-xp 00000000 08:01 377250 /lib/libdl-2.3.4.so
00d55000-00d57000 rwxp 00001000 08:01 377250 /lib/libdl-2.3.4.so
00da9000-00db1000 r-xp 00000000 08:01 376113 /lib/tls/librt-2.3.4.so
00db1000-00db3000 rwxp 00007000 08:01 376113 /lib/tls/librt-2.3.4.so
00db3000-00dbd000 rwxp 00db3000 00:00 0
00dbf000-00dce000 r-xp 00000000 08:01 377249 /lib/libresolv-2.3.4.so
00dce000-00dd0000 rwxp 0000f000 08:01 377249 /lib/libresolv-2.3.4.so
00dd0000-00dd2000 rwxp 00dd0000 00:00 0
0620e000-062e2000 r-xp 00000000 08:01 377251 /lib/libcrypto.so.0.9.7a
062e2000-062f4000 rwxp 000d4000 08:01 377251 /lib/libcrypto.so.0.9.7a
062f4000-062f7000 rwxp 062f4000 00:00 0
08048000-08057000 r-xp 00000000 08:02 2752562 /home2/java/jre/bin/java
08057000-08059000 rwxp 0000e000 08:02 2752562 /home2/java/jre/bin/java
08059000-0a279000 rwxp 08059000 00:00 0
68ace000-68ad4000 r-xp 00000000 08:02 2769008
/home2/java/jre/lib/i386/libnio.so
68ad4000-68ad5000 rwxp 00005000 08:02 2769008
68ad5000-68aed000 r-xp 00000000 08:02 2769003
/home2/java/jre/lib/i386/libdcpr.so
68aed000-68b00000 rwxp 00018000 08:02 2769003
68b00000-68c5c000 rwxp 68b00000 00:00 0
68c5c000-68d00000 ---p 68c5c000 00:00 0
68d00000-68e00000 rwxp 68d00000 00:00 0
68f41000-68fb9000 r-xp 00000000 08:02 2769006
/home2/java/jre/lib/i386/libfontmanager.so
68fb9000-68fc3000 rwxp 00078000 08:02 2769006
68fc3000-68fc7000 rwxp 68fc3000 00:00 0
69000000-690fb000 rwxp 69000000 00:00 0
690fb000-69100000 ---p 690fb000 00:00 0
69100000-691fc000 rwxp 69100000 00:00 0
691fc000-69200000 ---p 691fc000 00:00 0
69211000-69217000 r-xp 00000000 08:02 2769024
/home2/java/jre/lib/i386/headless/libmawt.so
69217000-69218000 rwxp 00005000 08:02 2769024
69218000-692de000 r-xp 00000000 08:02 2769011
/home2/java/jre/lib/i386/libmlib_image.so
692de000-692df000 rwxp 000c5000 08:02 2769011
69300000-693f1000 rwxp 69300000 00:00 0
693f1000-69400000 ---p 693f1000 00:00 0
69400000-694f5000 rwxp 69400000 00:00 0
694f5000-69500000 ---p 694f5000 00:00 0
69500000-696a1000 rwxp 69500000 00:00 0
696a1000-69700000 ---p 696a1000 00:00 0
69700000-69800000 rwxp 69700000 00:00 0
6983d000-698b2000 r-xp 00000000 08:02 2768992
/home2/java/jre/lib/i386/libawt.so
698b2000-698b8000 rwxp 00074000 08:02 2768992
698b8000-698dc000 rwxp 698b8000 00:00 0
69900000-69a00000 rwxp 69900000 00:00 0
69b00000-69bf7000 rwxp 69b00000 00:00 0
69bf7000-69c00000 ---p 69bf7000 00:00 0
69d00000-69dff000 rwxp 69d00000 00:00 0
69dff000-69e00000 ---p 69dff000 00:00 0
69f00000-6a000000 rwxp 69f00000 00:00 0
6a02f000-6a05e000 r-xp 00000000 08:02 2769012
/home2/java/jre/lib/i386/libjpeg.so
6a05e000-6a05f000 rwxp 0002e000 08:02 2769012
6a05f000-6a0d1000 r-xp 00000000 08:02 2769021
/home2/java/jre/lib/i386/libcmm.so
6a0d1000-6a0d4000 rwxp 00071000 08:02 2769021
6a100000-6a2fe000 rwxp 6a100000 00:00 0
6a2fe000-6a300000 ---p 6a2fe000 00:00 0
6a300000-6a4ff000 rwxp 6a300000 00:00 0
6a4ff000-6a500000 ---p 6a4ff000 00:00 0
6a500000-6a6f9000 rwxp 6a500000 00:00 0
6a6f9000-6a700000 ---p 6a6f9000 00:00 0
6a700000-6a900000 rwxp 6a700000 00:00 0
6a900000-6aa00000 rwxp 6a900000 00:00 0
6aa00000-6aaf6000 rwxp 6aa00000 00:00 0
6aaf6000-6ab00000 ---p 6aaf6000 00:00 0
6ac00000-6ad00000 rwxp 6ac00000 00:00 0
6ad00000-6adff000 rwxp 6ad00000 00:00 0
6adff000-6ae00000 ---p 6adff000 00:00 0
6aea7000-6aeb6000 r-xp 00000000 08:02 4899220
/home2/mapserver-5.0/fonts/lsans.ttf
6af00000-6b000000 rwxp 6af00000 00:00 0
6b000000-6b0f9000 rwxp 6b000000 00:00 0
6b0f9000-6b100000 ---p 6b0f9000 00:00 0
6b200000-6b300000 rwxp 6b200000 00:00 0
6b300000-6b3fd000 rwxp 6b300000 00:00 0
6b3fd000-6b400000 ---p 6b3fd000 00:00 0
6b500000-6b5ff000 rwxp 6b500000 00:00 0
6b5ff000-6b600000 ---p 6b5ff000 00:00 0
6b600000-6b6f0000 rwxp 6b600000 00:00 0
6b6f0000-6b700000 ---p 6b6f0000 00:00 0
6b800000-6baf8000 rwxp 6b800000 00:00 0
6baf8000-6bb00000 ---p 6baf8000 00:00 0
6bb00000-6bbff000 rwxp 6bb00000 00:00 0
6bbff000-6bc00000 ---p 6bbff000 00:00 0
6bc00000-6bd00000 rwxp 6bc00000 00:00 0
6bd00000-6be00000 rwxp 6bd00000 00:00 0
6bf00000-6bffe000 rwxp 6bf00000 00:00 0
6bffe000-6c000000 ---p 6bffe000 00:00 0
6c02c000-6c03a000 r-xp 00000000 08:02 4898978
/home2/mapserver-5.0/fonts/lsansd.ttf
6c03a000-6c03d000 ---p 6c03a000 00:00 0
6c03d000-6c0bb000 rwxp 6c03d000 00:00 0
6c0bb000-6c0be000 ---p 6c0bb000 00:00 0
6c0be000-6c13c000 rwxp 6c0be000 00:00 0
6c13c000-6c13f000 rwxp 6c13c000 00:00 0
6c13f000-6c1bd000 rwxp 6c13f000 00:00 0
6c1bd000-6c1c0000 rwxp 6c1bd000 00:00 0
6c1c0000-6c23e000 rwxp 6c1c0000 00:00 0
6c23e000-6c241000 ---p 6c23e000 00:00 0
6c241000-6c2bf000 rwxp 6c241000 00:00 0
6c2bf000-6c2c2000 rwxp 6c2bf000 00:00 0
6c2c2000-6c340000 rwxp 6c2c2000 00:00 0
6c340000-6c343000 ---p 6c340000 00:00 0
6c343000-6c3c1000 rwxp 6c343000 00:00 0
6c3c1000-6c3c2000 r-xp 00000000 08:02 2769026
/home2/java/jre/lib/i386/librmi.so
6c3c2000-6c3c3000 rwxp 00000000 08:02 2769026
6c3c3000-6c3c6000 rwxp 6c3c3000 00:00 0
6c3c6000-6c444000 rwxp 6c3c6000 00:00 0
6c444000-6c447000 ---p 6c444000 00:00 0
6c447000-6c4c5000 rwxp 6c447000 00:00 0
6c4c5000-6c4cb000 r-xs 00000000 08:01 211959
/usr/lib/gconv/gconv-modules.cache
6c4cb000-6c5f5000 r-xp 00000000 08:02 4899199
/home2/mapserver-5.0/geos/lib/libgeos-3.0.0.so
6c5f5000-6c5fa000 rwxp 0012a000 08:02 4899199
6c5fa000-6c628000 r-xp 00000000 08:01 189118 /usr/lib/libcurl.so.3.0.0
6c628000-6c62a000 rwxp 0002d000 08:01 189118 /usr/lib/libcurl.so.3.0.0
6c62a000-6c639000 r-xp 00000000 08:02 4899202
/home2/mapserver-5.0/geos/lib/libgeos_c.so.1.4.1
6c639000-6c63a000 rwxp 0000e000 08:02 4899202
6c63a000-6ca8b000 r-xp 00000000 08:02 4899214
/home2/mapserver-5.0/gdal/lib/libgdal.so.1.12.0
6ca8b000-6cae1000 rwxp 00451000 08:02 4899214
6cae1000-6cae3000 rwxp 6cae1000 00:00 0
6cae3000-6cb16000 r-xp 00000000 08:02 4898981
/home2/mapserver-5.0/proj4/lib/libproj.so.0.5.4
6cb16000-6cb18000 rwxp 00033000 08:02 4898981
6cb18000-6cb28000 r-xp 00000000 08:02 4915298
/home2/mapserver-5.0/agg/lib/libaggfontfreetype.so.2.0.4
6cb28000-6cb29000 rwxp 00010000 08:02 4915298
6cb29000-6cb58000 r-xp 00000000 08:02 4915294
/home2/mapserver-5.0/agg/lib/libagg.so.2.0.4
6cb58000-6cb5b000 rwxp 0002e000 08:02 4915294
6cb5b000-6cb7a000 r-xp 00000000 08:02 4898919
/home2/mapserver-5.0/libpng/lib/libpng12.so.0.24.0
6cb7a000-6cb7b000 rwxp 0001e000 08:02 4898919
6cb91000-6cbf6000 r-xp 00000000 08:02 4898829
/home2/mapserver-5.0/freetype/lib/libfreetype.so.6.3.16
6cbf6000-6cbfa000 rwxp 00064000 08:02 4898829
6cbfa000-6cc12000 r-xp 00000000 08:02 4898950
/home2/mapserver-5.0/gd/lib/libgd.so.2.0.0
6cc12000-6cc32000 rwxp 00017000 08:02 4898950
6cc32000-6cc36000 rwxp 6cc32000 00:00 0
6cc36000-6cd77000 r-xp 00000000 08:02 4915585
/home2/mapserver-5.0/mapscript/libmapscript.so
6cd77000-6cd7b000 rwxp 00140000 08:02 4915585
6cd7b000-6cd7d000 rwxp 6cd7b000 00:00 0
6cd7d000-6cd80000 ---p 6cd7d000 00:00 0
6cd80000-6cdfe000 rwxp 6cd80000 00:00 0
6cdfe000-6ce01000 ---p 6cdfe000 00:00 0
6ce01000-6ce7f000 rwxp 6ce01000 00:00 0
6ce7f000-6ce82000 ---p 6ce7f000 00:00 0
6ce82000-6cfff000 rwxp 6ce82000 00:00 0
6cfff000-6d000000 ---p 6cfff000 00:00 0
6d058000-6d05e000 rwxp 6d058000 00:00 0
6d05e000-6d061000 ---p 6d05e000 00:00 0
6d061000-6d0df000 rwxp 6d061000 00:00 0
6d0df000-6d0f3000 r-xp 00000000 08:02 2769002
/home2/java/jre/lib/i386/libnet.so
6d0f3000-6d0f4000 rwxp 00013000 08:02 2769002
6d0f4000-6d14c000 r-xs 00000000 08:02 4046860
/home2/idseg-gis-server/lib/log4j-1.2.13.jar
6d14c000-6d172000 r-xs 00000000 08:02 4915586
/home2/mapserver-5.0/mapscript/mapscript.jar
6d172000-6d1a7000 r-xs 00000000 08:02 4046861
/home2/idseg-gis-server/lib/idseg-pojo-1.0.0.jar
6d1a7000-6d1c9000 r-xs 00000000 08:02 4046863
/home2/idseg-gis-server/lib/dgt-util-1.0.0.jar
6d1c9000-6d1d3000 r-xs 00000000 08:02 4046862
/home2/idseg-gis-server/lib/commons-logging-1.0.4.jar
6d1d3000-6d1dc000 r-xs 00000000 08:02 4046858
/home2/idseg-gis-server/idseg-gis-server-1.0.6.jar
6d1dc000-6d207000 r-xs 00000000 08:02 2752587
/home2/java/jre/lib/ext/sunpkcs11.jar
6d207000-6d2cb000 r-xs 00000000 08:02 2752585
/home2/java/jre/lib/ext/localedata.jar
6d2cb000-6d2f2000 r-xs 00000000 08:02 2752584
/home2/java/jre/lib/ext/sunjce_provider.jar
6d2f2000-6d2f4000 r-xs 00000000 08:02 2752586
/home2/java/jre/lib/ext/dnsns.jar
6d2f4000-6d2f5000 ---p 6d2f4000 00:00 0
6d2f5000-6d375000 rwxp 6d2f5000 00:00 0
6d375000-6d378000 ---p 6d375000 00:00 0
6d378000-6d3f6000 rwxp 6d378000 00:00 0
6d3f6000-6d3f9000 ---p 6d3f6000 00:00 0
6d3f9000-6d477000 rwxp 6d3f9000 00:00 0
6d477000-6d47a000 ---p 6d477000 00:00 0
6d47a000-6d4f8000 rwxp 6d47a000 00:00 0
6d4f8000-6d4fb000 ---p 6d4f8000 00:00 0
6d4fb000-6d579000 rwxp 6d4fb000 00:00 0
6d579000-6d57c000 ---p 6d579000 00:00 0
6d57c000-6d5fa000 rwxp 6d57c000 00:00 0
6d5fa000-6d7fa000 r-xp 00000000 08:01 182537
/usr/lib/locale/locale-archive
6d7fa000-6d7fd000 ---p 6d7fa000 00:00 0
6d7fd000-6d87b000 rwxp 6d7fd000 00:00 0
6d87b000-6d87e000 ---p 6d87b000 00:00 0
6d87e000-6d8fc000 rwxp 6d87e000 00:00 0
6d8fc000-6d8fd000 ---p 6d8fc000 00:00 0
6d8fd000-6d97d000 rwxp 6d8fd000 00:00 0
6d97d000-6d97e000 ---p 6d97d000 00:00 0
6d97e000-6d9fe000 rwxp 6d97e000 00:00 0
6d9fe000-6d9ff000 ---p 6d9fe000 00:00 0
6d9ff000-6da7f000 rwxp 6d9ff000 00:00 0
6da7f000-6da80000 ---p 6da7f000 00:00 0
6da80000-6db00000 rwxp 6da80000 00:00 0
6db00000-6db01000 ---p 6db00000 00:00 0
6db01000-6db89000 rwxp 6db01000 00:00 0
6db89000-6dba1000 rwxp 6db89000 00:00 0
6dba1000-6dbbe000 rwxp 6dba1000 00:00 0
6dbbe000-6dd64000 rwxp 6dbbe000 00:00 0
6dd64000-6dd6c000 rwxp 6dd64000 00:00 0
6dd6c000-6dd84000 rwxp 6dd6c000 00:00 0
6dd84000-6dda1000 rwxp 6dd84000 00:00 0
6dda1000-6df46000 rwxp 6dda1000 00:00 0
6df46000-6df52000 rwxp 6df46000 00:00 0
6df52000-6df7f000 rwxp 6df52000 00:00 0
6df7f000-6ef80000 rwxp 6df7f000 00:00 0
6ef80000-71f80000 rwxp 6ef80000 00:00 0
71f80000-757d0000 rwxp 71f80000 00:00 0
757d0000-aa4e0000 rwxp 757d0000 00:00 0
aa4e0000-abb00000 rwxp aa4e0000 00:00 0
abb00000-b1580000 rwxp abb00000 00:00 0
b1587000-b1590000 rwxp b1587000 00:00 0
b1590000-b1647000 rwxp b1590000 00:00 0
b1647000-b1887000 rwxp b1647000 00:00 0
b1887000-b4647000 rwxp b1887000 00:00 0
b4647000-b4eb4000 r-xs 00000000 08:02 2753066
/home2/java/jre/lib/charsets.jar
b4eb4000-b4ec9000 r-xs 00000000 08:02 2753063 /home2/java/jre/lib/jce.jar
b4ec9000-b4f4e000 r-xs 00000000 08:02 2753062
/home2/java/jre/lib/jsse.jar
b4f4e000-b4fb7000 rwxp b4f4e000 00:00 0
b4fb7000-b75bb000 r-xs 00000000 08:02 2753054 /home2/java/jre/lib/rt.jar
b75bb000-b75ce000 r-xp 00000000 08:02 2768979
/home2/java/jre/lib/i386/libzip.so
b75ce000-b75d0000 rwxp 00012000 08:02 2768979
b75d0000-b75f1000 r-xp 00000000 08:02 2769001
/home2/java/jre/lib/i386/libjava.so
b75f1000-b75f3000 rwxp 00020000 08:02 2769001
b75f3000-b75fc000 r-xp 00000000 08:01 374674 /lib/libnss_files-2.3.4.so
b75fc000-b75fe000 rwxp 00008000 08:01 374674 /lib/libnss_files-2.3.4.so
b7600000-b760b000 r-xp 00000000 08:02 2768984
/home2/java/jre/lib/i386/libverify.so
b760b000-b760c000 rwxp 0000b000 08:02 2768984
b760c000-b7614000 rwxs 00000000 08:01 146611 /tmp/hsperfdata_root/30922
b7614000-b761a000 r-xp 00000000 08:02 2769018
/home2/java/jre/lib/i386/native_threads/libhpi.so
b761a000-b761b000 rwxp 00006000 08:02 2769018
b761b000-b761c000 rwxp b761b000 00:00 0
b761c000-b761d000 r-xp b761c000 00:00 0
b761d000-b7b6e000 r-xp 00000000 08:02 2768976
/home2/java/jre/lib/i386/server/libjvm.so
b7b6e000-b7bd0000 rwxp 00551000 08:02 2768976
b7bd0000-b7fe9000 rwxp b7bd0000 00:00 0
b7fff000-b8000000 rwxp b7fff000 00:00 0
bfe00000-bfe03000 ---p bfe00000 00:00 0
bfe03000-c0000000 rwxp bfe03000 00:00 0
ffffe000-fffff000 ---p 00000000 00:00 0
VM Arguments:
java_command: br.com.digitro.idseg.gis.rmi.GisServer
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=/usr/java/jdk
JRE_HOME=/usr/java/jre
CLASSPATH=/home2/idseg-gis-server/idseg-gis-server-1.0.6.jar:/home2/idseg-gis-server/lib/commons-logging-1.0.4.jar:.:/home2/idseg-gis-server/lib/dgt-util-1.0.0.jar:/home2/idseg-gis-server/lib/idseg-pojo-1.0.0.jar:/home2/idseg-gis-server/lib/mapscript.jar:/home2/idseg-gis-server/lib/log4j-1.2.13.jar
PATH=/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/usr/java/jre/bin:/usr/java/jdk/bin:/home2/mapserver/mapscript:/root/bin:/usr/java/jre/bin:/usr/java/jdk/bin:/home2/mapserver/mapscript
LD_LIBRARY_PATH=/home2/java/jre/lib/i386/server:/home2/java/jre/lib/i386:/home2/java/jre/../lib/i386:/home2/mapserver/proj4/lib:/home2/mapserver/gdal/lib:/home2/mapserver/geos/lib:/home2/mapserver/libcurl/lib:/home2/mapserver/libpng/lib:/home2/mapserver/ogdi/lib:/home2/mapserver/freetype/lib:/home2/mapserver/gd/lib:/home2/mapserver/zlib/lib:/home2/mapserver/proj4/share/proj:/home2/mapserver/mapscript:/home2/mapserver/agg/lib:/home2/mapserver/libiconv/lib/:/home2/mapserver/mapscript
SHELL=/bin/bash
Signal Handlers:
SIGSEGV: [libjvm.so+0x5016a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGBUS: [libjvm.so+0x5016a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGFPE: [libjvm.so+0x426c00], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGPIPE: [libjvm.so+0x426c00], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGILL: [libjvm.so+0x426c00], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x429050], sa_mask[0]=0x00000000, sa_flags=0x14000004
SIGHUP: [libjvm.so+0x428a80], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGINT: [libjvm.so+0x428a80], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGQUIT: [libjvm.so+0x428a80], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGTERM: [libjvm.so+0x428a80], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
--------------- S Y S T E M ---------------
OS:Red Hat Enterprise Linux AS release 4 (Nahant Update 4)
uname:Linux 2.6.9-42.0.10.ELsmp #1 SMP Fri Feb 16 17:17:21 EST 2007 i686
libc:glibc 2.3.4 NPTL 2.3.4
rlimit: STACK 10240k, CORE 0k, NPROC 77824, NOFILE 1024, AS infinity
load average:1.52 1.49 1.58
CPU:total 4 family 6, cmov, cx8, fxsr, mmx, sse, sse2, ht
Memory: 4k page, physical 1012k(3k free), swap 1000k(302k free)
vm_info: Java HotSpot(TM) Server VM (1.5.0_07-b03) for linux-x86, built
on May 3 2006 00:32:58 by java_re with gcc 3.2.1-7a (J2SE release)
