Please help me SDE C# asp.net and mapserver connection problem....
yatendra yatendra.jaiswal at GMAIL.COM
Mon Jan 21 01:46:46 EST 2008
Dear Tamas,
Thanks for reply.
I am trying as you suggested, but the problem is the same.
I am still getting same error.
Does any one have built mapserver sde and asp.net application successfully?
Thanks Regards
Tamas Szekeres wrote:
> 2008/1/18, yatendra <yatendra.jaiswal at gmail.com>:
>> Here is my mapfile layer....
>> LAYER
>>          CONNECTION "host=GEN387 port:5151 user=****** password=******
>> dbname=****"
>>                 CONNECTIONTYPE SDE
>>                 CONNECTIONTYPE PLUGIN
>>                 PLUGIN
>> "C:\ms4w\Apache\specialplugins\msplugin_sde_92.dll"
>>                  DATA "sde.SDE.TILE,SHAPE,sde.DEFAULT"
>>                  STATUS on
>>                  TYPE line
>> END
> Your application is possibly running under the context of the ASPNET
> user that may have limited security rights to access files outside of
> the application directory.
> You might want to copy this dll into you appdir as
>   On Windows 2003:   %SYSTEMROOT%\System32\inetsrv
>   On WIndows XP:   %SYTEMROOT%\Microsoft.NET\Framework\[framework version]
> whatever.
> And change your plugin definition as
> PLUGIN "msplugin_sde_92.dll"
>> If its because of asp.net version (64 bit), then what can be the
>> solution???
>> please let me know..
> This might be an issue only if your application is running on 64bit
> windows.
> In this case you should force to use the 32 bit version of the .NET
> framework and recompile mapscript by adding /platform:x86 to the csc
> command line in the /csharp/makefile.vc.
> This is because you cannot compile msplugin_sde_92.dll as an x64 image
> right now.
> Best regards,
> Tamas
View this message in context: http://www.nabble.com/Please-help-me-SDE-C--asp.net-and-mapserver-connection-problem....-tp14749790p14992030.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
