featureitemquery help
Paul Alarcon paul_pag00 at HOTMAIL.COM
Mon Jan 21 11:45:57 EST 2008
Hello
I am new here and  i am having some problems with this kind of query , when,
I`m using html for the page and postgis to create the layers  but when i
made the query a lot of map display each time and dont show me the
information please could you help me,
Here is the html and the map files
HTML
<html>
<head>
<title>Busqueda por CANTON</title>
<body>
<form name="consulta" method=GET action="/cgi-bin/mapserv">
  <input name="program" value="/cgi-bin/mapserv" type="hidden">
   <input name="map" value="/home/test/testexpression.map" type="hidden">
    <!-- parametros pasados en hidden -->
    <input name="mode" value="itemfeaturequery" type="hidden">
     <input name="slayer" value="cantones" type="hidden">
    <input name="qitem" value="non_canton" type="hidden">
    <input type="hidden" name="mapshape"   value="">
        <input type="hidden" name="imgshape"   value="">
        <input type="hidden" name="imgbox"     value="">
        <input type="hidden" name="shapeindex" value="">
    <!-- parametros de busqueda -->
    Seleccione un Cant&oacute;n: <br>
<select name="qstring" >
<option value="non_canton like 'LAGO AGRIO'">LAGO AGRIO</option>
<option value="non_canton like 'SUCUMBIOS'">SUCUMBIOS</option>
<option value="non_canton like 'GONZALO PIZARRO'">GONZALO PIZARRO</option>
<option value="non_canton like 'CASCALES'">CASCALES</option>
<option value="non_canton like 'SHUSHUFINDI'">SHUSHUFINDI</option>
<option value="non_canton like 'CUYABENO'">CUYABENO</option>
<option value="non_canton like 'PUTUMAYO'">PUTUMAYO</option></select>
<p>
<input value="BUSCAR" type="submit">
   </form>
</body>
  </html>
MAP FILE
MAP
  NAME test      #MapFile testing possible bug on itemquery
  STATUS ON
  SIZE 800 600
  EXTENT   836705.704288 9999113.003817 1143436.012879 10051849.051893
  STATUS ON
  #SHAPEPATH "/home/mapdata/Pichincha/pruebas/POLITICO 2002/"
  IMAGECOLOR 255 255 255
  IMAGETYPE PNG
  FONTSET "/srv/www/htdocs/ka-map/fontset.txt"
  WEB
    IMAGEPATH "/srv/www/htdocs/temp/"
    IMAGEURL "/temp/"
     TEMPLATE "querytemplate.html"
  END   # End of Web Interface
# Symbol para lineas gruesas
SYMBOL
      NAME "BigLine"
      TYPE ELLIPSE
      POINTS 1 1 END
END
# Symbol para puntos
SYMBOL
     NAME "Circle"
     FILLED true
     TYPE ellipse
     POINTS 1 1 END
END
#Symbol cuadrado base
SYMBOL
NAME "Cuadro"
TYPE VECTOR
POINTS
0 0
0 1
1 1
1 0
0 0
END
FILLED TRUE
END
#SYMBOL circulo
SYMBOL
NAME "punkt"
TYPE ELLIPSE
POINTS
1 1
END
FILLED TRUE
END
querymap
   status ON
   SIZE 400 300
   style SELECTED
   END
LAYER
    NAME cantones
    STATUS DEFAULT
    TYPE POLYGON
    CONNECTIONTYPE postgis
    CONNECTION "host=localhost port=5432 dbname=demo_postgis user=postgres
password="
    DATA "the_geom from cantones"
    LABELCACHE   on
    TOLERANCE 0
    METADATA
          qstring_validation_pattern '.'
    END
    LABELITEM   "non_canton"
    CLASS
       NAME "None"
       OUTLINECOLOR 0 0 0
       COLOR 187 212 201
    END
END  #end layer
############################################################3
LAYER
    NAME parroquias
    STATUS DEFAULT
    TYPE line
password="
     DATA "the_geom from parroquias"
     STATUS default
     #METADATA
    #      qstring_validation_pattern '.'
    #END
    LABELITEM   "parroquia"
    #DATA 'parroquial'
    CLASS
       NAME "None"
       #OUTLINECOLOR 100 0 0
       COLOR 0 5 5
    END
END  #end layer
LAYER
    NAME PROVINCIAS
    STATUS DEFAULT
    TYPE line
    #METADATA
    #END
    #LABELITEM   "PARROQUIA"
    #DATA 'provincial'
password="
     DATA "the_geom from provincial"
    CLASS
       NAME "None"
       COLOR 0 0 5
      STYLE
             SYMBOL "BigLine"
             SIZE 4
             #COLOR 50 212 51
             OUTLINECOLOR 12 0 0
        END
    END
END  #end layer
LAYER
       NAME "Escuelas"
user=postgres password="
       DATA "the_geom from sucumbios"
       STATUS default
       TYPE point
       LABELITEM "plantel"
       LABELCACHE  on
       HEADER "/srv/www/htdocs/head_plan.html"
       FOOTER "/srv/www/htdocs/foot_plan.html"
       CLASSITEM "nivel"
       METADATA
         "queryable" "true"
         "searchfield" "canton"
        # "fields" "canton:CANTON,parroqui_1:PARROQUIA,nombre_esc:NOMBRE"
       END
       GROUP "PLANTELES"
               CLASS
                 NAME "PREPRIMARIO"
                 EXPRESSION "Preprimario"
                     STYLE
                         SYMBOL "cuadro"
                         SIZE 10
                         COLOR  255 0 0
                         OUTLINECOLOR 0 0 0
                     END
               STYLE
                SYMBOL "punkt"
                SIZE 8
                COLOR  204 204 255
                OUTLINECOLOR 0 0 0
               END
               LABEL
                TYPE truetype
                FONT "DejaVuSerif"
                SIZE 8
	        COLOR 0 0 0
                #OUTLINECOLOR 0 0 0
                #BACKGROUNDCOLOR 255 255 255
                MINDISTANCE 20
                POSITION uc
                ANGLE 0.00
	        ANTIALIAS false
                BUFFER 20
               END #label
              END  #clase
          CLASS
           NAME "PRIMARIO"
           EXPRESSION "Primario"
           STYLE
             SYMBOL "cuadro"
             SIZE 10
             COLOR  0 255 0
             OUTLINECOLOR 0 0 0
           END
           STYLE
             SYMBOL "punkt"
             SIZE 8
             COLOR  204 204 255
             OUTLINECOLOR 0 0 0
           END
         LABEL
            TYPE truetype
            FONT "DejaVuSerif"
            SIZE 8
	    COLOR 0 0 0
            #OUTLINECOLOR 0 0 0
            MINDISTANCE 20
            POSITION uc
            ANGLE 0.00
	    ANTIALIAS false
            BUFFER 20
         END #label
      END # Clase
      CLASS
        NAME "MEDIO"
        EXPRESSION /^Medio/
        STYLE
             SYMBOL "cuadro"
             SIZE 10
             COLOR  0 0 255
             OUTLINECOLOR 0 0 0
        END
        STYLE
             SYMBOL "punkt"
             SIZE 8
             COLOR  204 204 255
             OUTLINECOLOR 0 0 0
        END
        LABEL
            TYPE truetype
            FONT "DejaVuSerif"
            SIZE 8
	    COLOR 0 0 0
            #OUTLINECOLOR 0 0 0
            MINDISTANCE 20
            POSITION uc
            ANGLE 0.00
	    ANTIALIAS false
            BUFFER 20
        END
      END
        CLASS
        NAME "S/Dato"
        EXPRESSION " "
        STYLE
             SYMBOL "Circle"
             SIZE 10
             COLOR  255 0 0
             OUTLINECOLOR 0 0 0
        END
        LABEL
            TYPE truetype
            FONT "DejaVuSerif"
            SIZE 8
	    COLOR 0 0 0
            #OUTLINECOLOR 0 0 0
            MINDISTANCE 50
            POSITION uc
            ANGLE 0.00
	    ANTIALIAS false
            BUFFER 20
        END
      END
END #LAYER
END  #end mapfile
_________________________________________________________________
MSN Amor: busca tu ½ naranja http://latam.msn.com/amor/
