is it possible to draw grd file using Mapserver
Murat Beyhan
beyhan at DEPREM.GOV.TR
Mon Jan 28 02:56:51 EST 2008
Dear Friend,
I have solved the problem which I published to the list.
Frank, As you said I have used GMT(grdtrack) to interpolate two layers.
Thank you very much for your interest.
Actually I was wondered to do this by mapServer because it is easy to
create dynamic map using mapserver.
Regards...
Murat
Frank Warmerdam wrote:
> Murat Beyhan wrote:
>> So I draw both layer by using it's .shp .dbf file.
>> As you see both are point file.
>> But I need to know if I draw both on the one map, Which villages
>> placed which zones.
>> Zones could created by using acceleration. For example 0-100 gal is
>> zone 1, 101-200gal is zone2, etc.
>> I guess, If you draw acceleration using point data you could not
>> distinguish data as zone.
>> May be by using point data I can obtain grid file or polygon file
>> than I can determine the village point place on the polygon.
>> When you draw acceleration distribution the shape of the distribution
>> seems circular area then when you classify zones you can get result
>> of the distribution which are divided into several level.
> Murat,
> It sounds like you need an algorithm to generate a raster by
> interpolation
> from your acceleration point data. There are many options to do this,
> but three that come to mind are GRASS, GMT or the gdal_grid program new
> in GDAL 1.5.
> Once you have an interpolated raster grid of the accelerations you could
> draw each class/range in a distinct color using classes to give a visual
> indication of the zones.
> If you want to know what the zone is for each village I would suggest
> doing this as a distinct processing step. Something where you sample the
> grid for each village location and attach a new column with the actual
> value, or the corresponding zone. This might be accomplished as a
> GDAL/OGR script (eg. in python). I'm sure this is also something that
> can be accomplished in GRASS and perhaps in GMT.
> I guess my main point is that you need to do various preprocessing steps
> before visualization and that these are best done in other packages more
> suited to the task. As we say "MapServer is not a GIS" which means we
> aren't
> trying to replicate all sorts of GIS processing in MapServer.
> All that said, in theory you could accomplish something vaguely
> similar in
> MapServer by writing a complicated mapscript script that for each village
> did a search for the nearest point and apply a zonation on that
> basis. But
> I wouldn't advise this approach for performance, complexity and
> inexactness
> reasons.
> Best regards,
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
