one way roads, drawing spaced arrows
rich.fromm nospam420 at YAHOO.COM
Tue Jan 22 13:46:01 EST 2008
thomas bonfort wrote:
> try
> GAP -5
> regards,
> thomas
Indeed, GAP -5 preserves the angle properly, while GAP 5 does not.
Is this the intended behavior, or just a workaround given some bug?  I can't
find anything in the documentation that suggest this.  I would have thought
that a negative gap would have flipped everything around in the opposite
direction.
From
http://mapserver.gis.umn.edu/docs/reference/symbology/referencemanual-all-pages
--- begin ---
GAP [int]
    Given in pixels. This defines a distance between symbols for TrueType
lines. As of MapServer 5.0 this also applies to PixMap symbols.
    When drawing the symbol along a line segment, a negative GAP will will
add 180 degress to the angle. The TrueType and PixMap symbols are always
oriented along the line. A GAP of 0 (the default value) will cause MapServer
to use the symbol as a brush to draw the line.
--- end ---
- Rich
View this message in context: http://www.nabble.com/one-way-roads%2C-drawing-spaced-arrows-tp15006747p15025423.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
