Map file with 35,000+ Lines... management issue
Espen Isaksen
espen.isaksen at GMAIL.COM
Wed Jan 23 14:26:10 EST 2008
Regarding this, is it possible to "include" a map file inside another map file?
Espen
On 23/01/2008, Fawcett, David <David.Fawcett at state.mn.us> wrote:
> Everything is a performance issue, the question is, 'Is the performance
> acceptable to you?'...
> You have built a pretty massive map file. I would look at stripping it
> down to only what is needed for a particular application.
> For questions about how to improve performance, you may want to look at:
> http://mapserver.gis.umn.edu/docs/howto/mapfiletuning
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of riteshambastha
> Sent: Wednesday, January 23, 2008 12:59 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Map file with 35,000+ Lines...
> management issue
> Thanks Rich,
> Yeah, even I am trying to solve this issue by separating the huge map
> file with smaller chunks of many map files. Am bit confused if it will
> lead to performance issues.
> Warm Regards,
> Ritz
> rich.fromm wrote:
> > riteshambastha wrote:
> >> I have developed a map file with more than 35,000 Lines.
> >> Please throw some lights over writing map files by following best
> >> practices.
> > Have you considered more than one map file, depending on the
> > circumstances, each one a bit smaller, rather than one huge map file?
> > It's hard to say how appropriate that may or may not be without
> > knowing more about your circumstances, but that's what I have.
> > - Rich
> http://www.nabble.com/Map-file-with-35%2C000%2B-Lines...-management-issu
> e-tp15048892p15048905.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
