Map file with 35,000+ Lines... management issue
Fawcett, David David.Fawcett at STATE.MN.US
Wed Jan 23 14:07:33 EST 2008
Everything is a performance issue, the question is, 'Is the performance
acceptable to you?'...
You have built a pretty massive map file.  I would look at stripping it
down to only what is needed for a particular application.
For questions about how to improve performance, you may want to look at:
http://mapserver.gis.umn.edu/docs/howto/mapfiletuning
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of riteshambastha
Sent: Wednesday, January 23, 2008 12:59 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Map file with 35,000+ Lines...
management issue
Thanks Rich,
Yeah, even I am trying to solve this issue by separating the huge map
file with smaller chunks of many map files. Am bit confused if it will
lead to performance issues.
Warm Regards,
Ritz
rich.fromm wrote:
> riteshambastha wrote:
>> I have developed a map file with more than 35,000 Lines.
>> Please throw some lights over writing map files by following best
>> practices.
> Have you considered more than one map file, depending on the
> circumstances, each one a bit smaller, rather than one huge map file?
> It's hard to say how appropriate that may or may not be without
> knowing more about your circumstances, but that's what I have.
> - Rich
View this message in context:
http://www.nabble.com/Map-file-with-35%2C000%2B-Lines...-management-issu
e-tp15048892p15048905.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
