WMS GetFeatureInfo
Bart van den Eijnden bartvde at GMAIL.COM
Wed Jan 30 12:31:23 EST 2008
Milo,
the WMS client determines the info_format. I assume QGIS is asking for MIME
or text/plain.
You need to add the following METADATA to your layers:
OWS_INCLUDE_ITEMS "all"
Maybe even GML_INCLUDE_ITEMS "all" I am not sure. Give it a try.
If Flamingo wants GML, it will request with
info_format=application/vnd.ogc.gml. If it doesn't you can probably set the
default/MIME format of Mapserver to this (METADATA at the WEB level called
feature_info_mime_type).
Template can remain empty, I always TEMPLATE blank.html where
blank.htmldoes not even exist on the filesystem.
Best regards,
Bart
On Jan 30, 2008 5:48 PM, Milo van der Linden <mlinden at zeelandnet.nl> wrote:
> Hello list,
> I have been spending 4 hours looking around the mapserver website and
> various other resources but no luck.
> As a Mapserver WMS client I am using flamingo-mc. flamingo-mc is able to
> perform a getFeatureInfo and requires gml as response.
> For now I have some sort of response because with qGIS I get:
> WMS identify result for 225, 337
> GetFeatureInfo results:
> Layer 'percelen'
> Feature 507:
> But it is clearly no gml and I haven't set the fields from the table to
> be returned.
> So:
> - What do I have to put in my (currently empty) TEMPLATE file?
> - Can I enter all the GML that I need to return in my TEMPLATE and does
> anyone have a sample for this?
> - How can I make sure that the information returned is in the gml
> mime-type?
> Any help would be appreciated!
> Kind regards,
> Milo van der Linden
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080130/b477fbf7/attachment.html
