[mapserver-users] shape, SLD and Latin-1
Guillaume Sueur guillaume.sueur at neogeo-online.net
Mon Jun 2 12:15:29 EDT 2008
Hi list,
I'm facing a character set problem.
People are uploading shapefiles onto a web platform. The shapefiles are
then displayed via mapserver, using SLD for styling. On some shapes,
there is a specific pattern to follow, and I use Rules in my SLD for
this. Until here, everything is fine.
But if the field on which I build the rule on contains specific
characters (éè...), even if the same is written into the SLD file, it
doesn't match.
Where should I start my investigation from, knowing I don't control the
upcoming shapefiles, but I can transform them ? Is there a common
character set I could apply to both DBF and SLD for mapserver to match
the values ?
Thanks !
Guillaume
