[mapserver-users] Label Line Layers Question
Léveillé, James
James.Leveille at mtq.gouv.qc.ca
Mon Jun 2 15:09:03 EDT 2008
Here is an example
# ========== Hydrographie linéaire avec toponymes ==========
LAYER
NAME "hyd_lin_topnm"
PROJECTION
"init=epsg:42105"
END
METADATA
"wms_name" "Hydrographie linéaire avec toponymes"
"wms_title" "Hydrographie linéaire avec toponymes"
"wms_abstract" "Hydrographie linéaire avec toponymes"
"wms_srs" "EPSG:4326 EPSG:4269 EPSG:42105 EPSG:32198"
END
STATUS ON
DUMP TRUE
EXTENT 30000 75000 1709360 2120440
MAXSCALE 150000
MINSCALE 1
TYPE LINE
DATA "hydro/hyd_lin_topnm/hydrg_bdat_l100k_20080130"
LABELITEM "TOPONYME"
CLASS
STYLE
COLOR 213 210 240
END
LABEL
TYPE TRUETYPE
FONT "verdana"
SIZE 8
ANGLE FOLLOW
COLOR 25 25 175
OUTLINECOLOR 255 255 255
MINDISTANCE 600
PARTIALS FALSE
END
END
END
______________________________________________________
JAMES LÉVEILLÉ
Service des systèmes de Mission
Direction des technologies de l'information
Ministère des Transports du Québec
5833, boul. Pierre-Bertrand, 2ième étage
Québec (Québec) G2K 1K7
Téléphone: (418) 380-2005 poste 227
Télécopieur: (418) 644-6653
james.leveille at mtq.gouv.qc.ca
-----Message d'origine-----
De : mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] De la part de Jeshua Lacock
Envoyé : 2 juin 2008 15:06
À : mapserver-users at lists.osgeo.org
Objet : [mapserver-users] Label Line Layers Question
Greetings,
I am working on a tutorial for MapServer using a Postgis backend, and
I just want to check if I am setting a correct example. This is my
first .map file so please forgive me for my noob question.
Is there a way to have text labels and lines on the same layer?
Instead of two Postgis queries, I was wondering if it is possible to
do with a single query.
Here is the pertinent portion of my .map files:
LAYER
CONNECTIONTYPE postgis
NAME "roads"
CONNECTION "user=postgres dbname=ca_hwy host=localhost"
DATA "the_geom FROM (SELECT roads.oid AS oid, roads.the_geom AS
the_geom, roads.fename AS fename FROM roads) AS named_roads USING
UNIQUE oid USING SRID=-1"
STATUS ON
TYPE ANNOTATION
LABELITEM fename
CLASS
LABEL
POSITION auto
ANGLE follow
SHADOWCOLOR 120 255 120
SHADOWSIZE 1 1
SIZE 8
COLOR 0 192 0
FONT sans-bold
TYPE truetype
BUFFER 4
MINDISTANCE 200
ANTIALIAS TRUE
END
END
END
LAYER
NAME "roads"
DATA "the_geom FROM roads USING UNIQUE oid USING SRID=-1"
STATUS ON
TYPE LINE
CLASS
SIZE 2
COLOR 0 0 0
END
END
Thanks,
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 877.240.1364
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
