[mapserver-users] Label Line Layers Question
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jun 2 17:33:44 EDT 2008
Yup,
 > LAYER
 >   CONNECTIONTYPE postgis
 >   NAME "roads"
 >   CONNECTION "user=postgres dbname=ca_hwy host=localhost"
 >   DATA "the_geom FROM (SELECT roads.oid AS oid, roads.the_geom AS
 > the_geom, roads.fename AS fename FROM roads) AS named_roads USING UNIQUE
 > oid USING SRID=-1"
 >   STATUS ON
 >   TYPE LINE
 >   LABELITEM fename
 >   CLASS
 >     SIZE 2
 >     COLOR 0 0 0
 >     LABEL
 >       POSITION auto
 >       ANGLE follow
 >       SHADOWCOLOR 120 255 120
 >       SHADOWSIZE 1 1
 >       SIZE 8
 >       COLOR 0 192 0
 >       FONT sans-bold
 >       TYPE truetype
 >       BUFFER 4
 >       MINDISTANCE 200
 >       ANTIALIAS TRUE
 >     END
 >   END
 > END
-Steve W
Jeshua Lacock wrote:
> Greetings,
> I am working on a tutorial for MapServer using a Postgis backend, and I
> just want to check if I am setting a correct example. This is my first
> .map file so please forgive me for my noob question.
> Is there a way to have text labels and lines on the same layer? Instead
> of two Postgis queries, I was wondering if it is possible to do with a
> single query.
> Here is the pertinent portion of my .map files:
> LAYER
>   NAME "roads"
> oid USING SRID=-1"
>   STATUS ON
>   TYPE ANNOTATION
>   LABELITEM fename
>   CLASS
>     LABEL
>       POSITION auto
>       ANGLE follow
>       SHADOWSIZE 1 1
>       SIZE 8
>       COLOR 0 192 0
>       FONT sans-bold
>       TYPE truetype
>       BUFFER 4
>       MINDISTANCE 200
>       ANTIALIAS TRUE
>     END
>   END
> END
> LAYER
>   NAME "roads"
>   DATA "the_geom FROM roads USING UNIQUE oid USING SRID=-1"
>   STATUS ON
>   TYPE LINE
>   CLASS
>     SIZE 2
>     COLOR 0 0 0
>   END
> END
> Thanks,
> Jeshua Lacock, Owner
> <http://OpenOSX.com>
> phone: 877.240.1364
> mapserver-users at lists.osgeo.org
