[mapserver-users] Problem with Mapserver WFS-client generated syntax
Yewondwossen Assefa yassefa at dmsolutions.ca
Wed Jun 4 14:35:24 EDT 2008
Robert,
  The wfs specs indicates that values for the BBOX parameter should be
separated by commas which is what Mapserver is doing. There is no other
setting in mapserver that would allow you to change the format of BBOX
easily. I think the best would be for the server to respect the syntax
described in the specs.
Best Regards,
Burgholzer,Robert wrote:
> Hey folks,
> I am trying to hit NOAA’s experimental point based weather forecast
> product WFS server.  I am using mapserver as a client, and I seem to be
> getting a strange incompatibility, that appears to be in a subtle
> feature of the WFS query that Mapserver is putting together.  The
> difference between the query that NOAA wants, and the one that mapserver
> produces is in the BBOX parameter.  NOAA wants a space between the two
> corners, and mapserver puts a comma, a la:
> NOAA Wants:
> BBOX=-79.6222567785354,37.8816528320313 -77.4274563562303,39.3436317443848
> Mapserver Sends:
> BBOX=-79.6222567785354,37.8816528320313,-77.4274563562303,39.3436317443848
> Doesn’t Work (mapserver):
> http://www.weather.gov/forecasts/xml/OGC_services/ndfdOWSserver.php?&REQUEST=GetFeature&VERSION=1.0.0&SERVICE=WFS&TYPENAME=Ndfd_KmlPoint&BBOX=-79.6222567785354,37.8816528320313,-77.4274563562303,39.3436317443848
> <http://www.weather.gov/forecasts/xml/OGC_services/ndfdOWSserver.php?&REQUEST=GetFeature&VERSION=1.0.0&SERVICE=WFS&TYPENAME=Ndfd_KmlPoint&BBOX=-79.6222567785354,37.8816528320313,-77.4274563562303,39.3436317443848>
> Works (NOAA):
> http://www.weather.gov/forecasts/xml/OGC_services/ndfdOWSserver.php?&REQUEST=GetFeature&VERSION=1.0.0&SERVICE=WFS&TYPENAME=Ndfd_KmlPoint&BBOX=-79.6222567785354,37.8816528320313%20-77.4274563562303,39.3436317443848
> Maybe I am missing some crucial configuration param?
> Thanks in advance,
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> rwburgholzer at deq.virginia.gov <mailto:rwburgholzer at deq.virginia.gov>
> 804-698-4405
> Open Source Modeling Tools:
> http://sourceforge.net/projects/npsource/
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
