[mapserver-users] Problem with Mapserver WFS-client generated syntax
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Wed Jun 4 15:03:00 EDT 2008
Thanks for letting me know that it is their problem, not mapserver.
Hopefully, they can fix it...
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
Sent: Wednesday, June 04, 2008 2:35 PM
To: Burgholzer,Robert
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Problem with Mapserver WFS-client
generated syntax
Robert,
  The wfs specs indicates that values for the BBOX parameter should be
separated by commas which is what Mapserver is doing. There is no other
setting in mapserver that would allow you to change the format of BBOX
easily. I think the best would be for the server to respect the syntax
described in the specs.
Best Regards,
Burgholzer,Robert wrote:
> Hey folks,
> I am trying to hit NOAA's experimental point based weather forecast
> product WFS server.  I am using mapserver as a client, and I seem to
be
> getting a strange incompatibility, that appears to be in a subtle
> feature of the WFS query that Mapserver is putting together.  The
> difference between the query that NOAA wants, and the one that
mapserver
> produces is in the BBOX parameter.  NOAA wants a space between the two
> corners, and mapserver puts a comma, a la:
> NOAA Wants:
> BBOX=-79.6222567785354,37.8816528320313
-77.4274563562303,39.3436317443848
> Mapserver Sends:
BBOX=-79.6222567785354,37.8816528320313,-77.4274563562303,39.34363174438
48
> Doesn't Work (mapserver):
http://www.weather.gov/forecasts/xml/OGC_services/ndfdOWSserver.php?&REQ
UEST=GetFeature&VERSION=1.0.0&SERVICE=WFS&TYPENAME=Ndfd_KmlPoint&BBOX=-7
9.6222567785354,37.8816528320313,-77.4274563562303,39.3436317443848
<http://www.weather.gov/forecasts/xml/OGC_services/ndfdOWSserver.php?&RE
QUEST=GetFeature&VERSION=1.0.0&SERVICE=WFS&TYPENAME=Ndfd_KmlPoint&BBOX=-
79.6222567785354,37.8816528320313,-77.4274563562303,39.3436317443848>
> Works (NOAA):
9.6222567785354,37.8816528320313%20-77.4274563562303,39.3436317443848
> Maybe I am missing some crucial configuration param?
> Thanks in advance,
> rwburgholzer at deq.virginia.gov <mailto:rwburgholzer at deq.virginia.gov>
> 804-698-4405
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
