[mapserver-users] mapserver wms: srs problem
Barend Kobben
kobben at itc.nl
Sun Jun 8 14:08:23 EDT 2008
It looks like your datastore's SRS is 4326 (latlon on the WGS84). In other
words, the data in your shapefile, database or raster image are (or are
advertised to be) in 4326. Its because your data is indeed in that srs
and/or advertised as such in the Mapfile LAYER as
PROJECTION
"init=epsg:4326"
END
But you tell the WMS interface that the layer is in 26915, by setting layer
metadata srs => EPSG:26915
If you want MS to reproject your data from 4326 to 26915 upon request, make
sure you set the layerdata projection:
PROJECTION
"init=epsg:4326"
END
Then make sure you tell the WMS interface to advertise it can be reprojected
to 26915 by setting it in web metadata srs:
"wms_srs" "EPSG:4326 EPSG:26915 EPSG:[others you want to offer]"
AFAIK there no wms_srs metadata in the LAYER object...
Barend Köbben
International Institute for Geo-Information
Sciences and Earth Observation (ITC)
PO Box 6
7500AA Enschede, The Netherlands
+31 (0)53 4874253
On 08-06-08 02:21, "Matthew Pettis" <matthew.pettis at gmail.com> wrote:
> Hi,
> I am not a GIS guy, and am a bit confused by the projection attributes
> i have to specify in mapserver. In particular, I have a simple
> example. I have a map that has the following metadata:
> Horizontal Coordinate Scheme UTM
> Ellipsoid GRS80
> Horizontal Datum NAD83
> Horizontal Units Meters
> UTM Zone Number 15
> I believe this translates to an epsg=26915
> Now, according to mapserver, I have to specify a projection object, a
> web metadata srs, and a layer metadata srs.
> To compress the mapfile, i'll just note what i have specified for each
> of these settings.
> First, I would think that this would work:
> projection => init=epsg:26915
> web metadata srs => EPSG:26915
> layer metadata srs => EPSG:26915
> this give me the error:
> msWMSLoadGetMapParams(): WMS Server Error. Invalid SRS given. SRS
> must be valid for all requested layers.
> I only have the one layer (it's of the state of MN from www.gis.leg.mn).
> However, the following renders, but I don't think it is the projection
> i want (as the top of MN is too wide):
> layer metadata srs => EPSG:4326
> Now, I am using mapserver as a WMS. Before I was using it NOT as a
> WMS, but just making it render the shapefile without any projection
> information, it worked, and it was the projection I had come to expect
> when seeing the state of MN rendered.
> Why does my first configuration give me an error?
> How can I make it render in the way I expect without giving mapserver
> explicit projection instructions?
> please forgive the ignorance of map projection knowledge.
> thanks,
> matt
International Institute for Geo-Information Science and Earth Observation (ITC)
Chamber of Commerce: 410 27 560
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
