[mapserver-users] Mapscript BINDING constants
Rob
gis at vanbooth.com
Mon Jun 16 09:12:49 EDT 2008
I've raised Ticket #2643.
In the meantime, how would I hack my way around this issue? At the
end of the day, the JNI will be expecting some kind of integer value,
but I have no way of knowing what that value is.
2008/6/16 Tamas Szekeres <szekerest at gmail.com>:
> Hi Rob,
> These constants haven`t been exposed to the SWIG interface, however
> I`m not aware of any compelling reason why not to do so.
> You can submit a ticket with this problem.
> Best regards,
> Tamas
> 2008/6/16 Rob <gis at vanbooth.com>:
>> Hi
>> I'm trying to migrate from 4.8.6 to 5.0.2 and have a query regarding
>> Mapscript constants.
>> Given the change from LABELANGLEITEM to a binding on the Label, I'm
>> struggling to see how this would work in Mapscript/Java.
>> If I understand it correctly (and I'm not a Java developer by any
>> means) to replace
>> LABEL
>> ANGLE [ATTRIBUTE]
>> END
>> I need a line like
>> labelObj.setBinding(MS_LABEL_BINDING_ANGLE, "ATTRIBUTE");
>> However, there doesnt seem to be anything defining the
>> MS_LABEL_BINDING_ANGLE constant anywhere for me to compile against.
>> Do I need to build my own constants?
>> MTIA
>> Rob
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
