[mapserver-users] Mapscript BINDING constants
Tamas Szekeres szekerest at gmail.com
Mon Jun 16 09:24:43 EDT 2008
Rob,
Added a patch that should be a fix for it:
http://trac.osgeo.org/mapserver/attachment/ticket/2643/mapserver.h.patch
Best regards,
Tamas
2008/6/16 Rob <gis at vanbooth.com>:
> I've raised Ticket #2643.
> In the meantime, how would I hack my way around this issue?  At the
> end of the day, the JNI will be expecting some kind of integer value,
> but I have no way of knowing what that value is.
> 2008/6/16 Tamas Szekeres <szekerest at gmail.com>:
>> Hi Rob,
>> These constants haven`t been exposed to the SWIG interface, however
>> I`m not aware of any compelling reason why not to do so.
>> You can submit a ticket with this problem.
>> Best regards,
>> Tamas
>>> Hi
>>> I'm trying to migrate from 4.8.6 to 5.0.2 and have a query regarding
>>> Mapscript constants.
>>> Given the change from LABELANGLEITEM to a binding on the Label, I'm
>>> struggling to see how this would work in Mapscript/Java.
>>> If I understand it correctly (and I'm not a Java developer by any
>>> means) to replace
>>> LABEL
>>>     ANGLE [ATTRIBUTE]
>>> END
>>> I need a line like
>>> labelObj.setBinding(MS_LABEL_BINDING_ANGLE, "ATTRIBUTE");
>>> However, there doesnt seem to be anything defining the
>>> MS_LABEL_BINDING_ANGLE constant anywhere for me to compile against.
>>> Do I need to build my own constants?
>>> MTIA
>>> Rob
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
