R: VS: [mapserver-users] using vector data format
David Martinez Morata
damarmo at gmail.com
Wed Jun 18 09:56:37 EDT 2008
Hi.
I don't know if that can help but maby its a 14 version dwg the dwg you
need.
I work with Autocad Map and most symple version of dwg its the 14 dwg. but
Any way if thants not work try with Dxf format.
2008/6/18 valerio vianello <valerio.vianello at yahoo.it>:
> Hi Jukka,
> I took the list from http://mapserver.gis.umn.edu/docs/howto/ogr_howto and
> there
> autocad format is present among supported vector format. maybe that list
> isn't updated :S.
> Anyhow my problem is that my start image is a svg file and I used a
> software to convert it in autocad format.
> Do you know a software to convert svg file in another vector format
> supported by mapserver ?
> thanks
> Valerio
> --- *Mer 18/6/08, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>* ha scritto:
> Da: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Oggetto: VS: [mapserver-users] using vector data format
> A: valerio.vianello at yahoo.it, "mapserver" <mapserver-users at lists.osgeo.org
> Data: Mercoledì 18 giugno 2008, 15:01
> Hi,
> Your problem is that Mapserver does not support AutoCAD dwg file format. You
> need to convert it first to some supported format, which are listed at
> http://gdal.org/ogr/ogr_formats.html
> -Jukka Rahkonen.
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: valerio
> vianello
> Lähetetty: ke 18.6.2008 12:24
> Vastaanottaja: mapserver
> Aihe: [mapserver-users] using vector data format
> Dear all,
> I tried without success to use a dwg file as data input for a layer into the
> mapfile.
> My goal is to use a vector data to build the main layer of the map so that when
> the map is "resize" the image quality will be good at every size.
> Mapserver give me this error "File not found or unsupported
> format."
> and my test map file is this:
> MAP
> IMAGETYPE PNG
> EXTENT 24.914925 60.162912
> 24.917090 60.164152
> SIZE 300 200
> SHAPEPATH "/var/www/"
> IMAGECOLOR 255 255 255
> WEB
> TEMPLATE 'test.html'
> IMAGEPATH '/var/www/tmp/data_tmp/'
> IMAGEURL '/tmp/data_tmp/'
> END
> # Start of LAYER DEFINITIONS
> LAYER
> NAME "test"
> TYPE POLYGON
> CONNECTIONTYPE OGR
> CONNECTION "/var/www/demo1/images/b1_f2.dwg"
> STATUS DEFAULT
> CLASS
> END
> END
> END
> any suggetsion ?
> Thanks
> Valerio
> ___________________________________
> Scopri il Blog di Yahoo! Mail: trucchi, novità, consigli... e la tua opinione!
> http://www.ymailblogit.com/blog/
> Scopri il Blog di Yahoo! Mail<http://us.rd.yahoo.com/mail/it/taglines/yahoo/ymail/SIG=11djrg460/**http%3A%2F%2Fwww.ymailblogit.com%2Fblog%2F>:
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080618/98a5b0db/attachment.html
