[mapserver-users] transparent symbol clobbering
Zak James
zak4ms at gmail.com
Thu Jun 26 15:53:55 EDT 2008
Ben,
I think there probably is a bug in the case of GD output with 24 bit
icons on a transparent background. If you have the agg driver
configured, setting TRANSPARENT TRUE in the map and using the built-in
aggpng24 outputformat works.
If you want the result to be 8-bits deep, you could try enabling
--with-experimental-png. See
http://trac.osgeo.org/mapserver/ticket/2436 for some background.
zak
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
On Thu, Jun 26, 2008 at 2:58 PM, Ben Brehmer <bbrehmer at refractions.net> wrote:
> Thanks Paul,
> Unfortunately no luck. Setting "transparency alpha" makes the transparent
> part around the symbols completely white :)
> It seems to be the exact same problem as Jim Clack encountered [1], who
> never found a solution either. Makes me think its actually a bug and not
> intended behavior. Perhaps I'll start digging through the code.
> Cheers,
> Ben
> [1]
> http://www.mail-archive.com/mapserver-users@lists.osgeo.org/msg00569.html
> Paul Spencer wrote:
>> just a guess, try transparency alpha
>> Cheers
>> Paul
>> On 25-Jun-08, at 7:33 PM, Ben Brehmer wrote:
>>> I have a very simple mapfile to display a bunch of points as PNG symbols.
>>> Problem is that the transparent part of the symbols are clobbering each
>>> other with the background color (see attached image). What I would like to
>>> see is a whole wack of merged together symbols when they are overlapping
>>> without the background color coming through.
>>> Any thoughts as to what could be causing this?
>>> Cheers,
>>> Ben Brehmer
>>> The relevant parts of my very simple map file:
>>> MAP
>>> TRANSPARENT ON
>>> OUTPUTFORMAT
>>> NAME PNG24
>>> DRIVER "GD/PNG"
>>> MIMETYPE "image/png"
>>> EXTENSION "png"
>>> IMAGEMODE RGBA
>>> TRANSPARENT ON
>>> END
>>> LAYER
>>> TRANSPARENCY 100
>>> CLASS
>>> STYLE
>>> SYMBOL "../../htdocs/images/markers/multi_arrow.png"
>>> SIZE 32
>>> END #STYLE
>>> END #CLASS
>>> <transparent_symbol_issue.jpg>_______________________________________________
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Paul Spencer
>> Chief Technology Officer
>> http://www.dmsolutions.ca/
