[mapserver-users] GetFeatureInfo XML result is not encoded at all
Guillaume Sueur guillaume.sueur at neogeo-online.net
Fri Jun 27 15:00:30 EDT 2008
I don't think they can even imagine what a character set is. I assume
it's LATIN1, and get some bad results some times.
Too bad...
Guillaume
Daniel Morissette a écrit :
> Guillaume Sueur wrote:
>> That's not so easy when you don't know the encoding of the data used.
>> In a current project I have, people upload their data to be published
>> via WMS.
>> Would it be a big deal to add conversion of the result on the fly ?
> In which format do they upload their data? Chances are that if you don't
> know the encoding then MapServer would have no way to guess it either.
> For instance, I most DBF files do not come with any encoding information
> so you need to guess what it is.
> Assuming we have a way to determine the encoding of the data, or that we
> add some parameter at the layer level to let the admin specify it, then
> yes it would be technically possible to implement encoding conversions
> in MapServer. We already do that in the case of LABELs for instance (see
> the LABEL ENCODING param).
> Daniel
