[mapserver-users] finding php_mapserver.so
Tim McGeary tmm8 at Lehigh.EDU
Thu May 1 13:13:26 EDT 2008
I did the make again for kicks and sure enough it is there now.  That is
so odd because I know I did that before.
Thank you for being persistent and patient with me.
Cheers,
Tim
Tim McGeary
Senior Systems Specialist
Lehigh University
610-758-4998
tim.mcgeary at lehigh.edu
Google Talk: timmcgeary
Yahoo IM: timmcgeary
Kyle Wilcox wrote:
> After you run configure, compile mapserver:
> ]$  make
> You should see something like this at the end:
> make[1]: Entering directory `/mapserver/directory/mapscript/php3'
> g++ -shared   -o php_mapscript.so php_mapscript_util.o php_mapscript.o
> mapscript_i.o php_regex.o  -L/mapserver/directory -lmapserver -ltiff
> -ljpeg -lfreetype -lpng -lz -lXpm -lX11  -ljpeg -lgd -L/usr/lib -lgd
> -ljpeg -lfreetype -lpng -lz -lXpm -lX11  -lc -lz   -lm -lstdc++
> make[1]: Leaving directory `/mapserver/directory/mapscript/php3'
> ]$ ls mapscript/php3/php_mapscript.so
> If it isn't there, go into the mapscript/php3 directory and type:
> ]$ make clean && make
> If that doesn't work it is beyond my knowledge!  I just know what I've
> read in the documentation.
> Tim McGeary wrote:
>> I did specify the --with-php=DIR as --with-php=/usr/include/php/
>> Here's the output of the configure script for the PHP/Mapscript:
>> configure: checking for PHP/MapScript module options...
>> checking for g++ -shared ... yes
>> checking for location of config.h or php_config.h...
>> /usr/include/php//main/php_config.h
>> checking whether we have PHP3 or PHP4... -DPHP4
>> checking whether we should use PHP's regex... yes
>>    found regex_extra.h - building PHP MapScript with PHP's bundled regex
>>    PHP/MapScript module configured.
>> checking if --enable-runpath requested... no
>> checking if --with-java-include-os-name specified... no, autodetected
>> linux
>> configure: creating ./config.status
>> config.status: creating Makefile
>> config.status: creating mapscript/php3/Makefile
>> config.status: creating mapscript/java/Makefile
>> config.status: creating mapscript/csharp/Makefile
>> MapServer is now configured for
>>  -------------- Compiler Info -------------
>>   C compiler:                gcc -O2 -fPIC -Wall
>>   C++ compiler:              g++ -O2 -fPIC -Wall
>>   Debug:                      -DNEED_NONBLOCKING_STDERR
>>   Generic NINT:
>>   Threading support:
>>  -------------- Renderer Settings ---------
>>   zlib support:
>>   png support:
>>   jpeg support:              -DUSE_JPEG
>>   iconv support:             -DUSE_ICONV
>>   AGG support:
>>   AGG Freetype support:
>>   Ming(flash) support:
>>   PDFLib support:
>>  -------------- Data Format Drivers -------
>>   native tiff support:       -DUSE_TIFF
>>   PostGIS support:
>>   Proj.4 support:
>>   EPPL7 support:             -DUSE_EPPL
>>   ArcSDE support:
>>   OGR support:
>>   GDAL support:
>>   GEOS support:
>>   Oracle Spatial support:
>>   FastCGI support:
>>  -------------- OGC Services --------------
>>   WMS Server:
>>   WMS Client:
>>   WFS Server:
>>   WFS Client:
>>   WCS Server:
>>   SOS Server:
>>  -------------- MapScript -----------------
>>   PHP MapScript:             yes
>> FYI, I'm running PHP 5.1.6
>> Tim
>> Tim McGeary
>> Lehigh University
>> 610-758-4998
>> Kyle Wilcox wrote:
>>> Did you specify the --with-php=DIR?
>>> DIR is obviously the directory of the php version you want to use.
>>> Step through the output from ./configure and see what it says about
>>> PHP/Mapscript.  I think it is towards the end.
>>> Tim McGeary wrote:
>>>> No, it isn't there.  I did a:
>>>>    find / -name php_mapscript.so
>>>> and it came up with nothing.  So it isn't on the server at all.
>>>> Yes, I did install Mapserver from source.
>>>> Here's what is in mapscript/php3
>>>> [root at rust php3]# pwd
>>>> /usr/local/mapserver-5.0.2/mapscript/php3
>>>> [root at rust php3]# ls -l
>>>> total 716
>>>> drwxr-xr-x  2 root root   4096 Jan 28 10:56 examples
>>>> -rw-r--r--  1 root root   2103 Jul 26  2004 hashtable_i.c
>>>> -rw-r--r--  1 root root   4344 Apr 29 15:37 Makefile
>>>> -rwxr-xr-x  1 root root   3770 Jun 11  2007 Makefile.in
>>>> -rwxr-xr-x  1 root root   2097 Feb 14  2006 Makefile.vc
>>>> -rwxr-xr-x  1 root root  34328 Aug 16  2007 mapscript_i.c
>>>> -rw-r--r--  1 root root   1049 Feb 14  2006 nmake.opt
>>>> -rwxr-xr-x  1 root root 502728 Jan  8 12:04 php_mapscript.c
>>>> -rwxr-xr-x  1 root root  16760 Aug 16  2007 php_mapscript.h
>>>> -rw-r--r--  1 root root  17046 Jun 15  2007 php_mapscript_util.c
>>>> -rw-r--r--  1 root root   7450 Jun 15  2007 php_mapscript_util.h
>>>> -rw-r--r--  1 root root  25958 Jun 14  2005 php_proj.c
>>>> -rw-r--r--  1 root root   3103 Jul 23  2007 php_regex.c
>>>> -rwxr-xr-x  1 root root  68315 Jan  8 12:04 README
>>>> -rwxr-xr-x  1 root root   3821 Jun 21  2001 README.WIN32
>>>> Thanks,
>>>> Tim
>>>> Tim McGeary
>>>> Lehigh University
>>>> 610-758-4998
>>>> Kyle Wilcox wrote:
>>>>> If you installed Mapserver from source with the  ---with-php=DIR
>>>>> option and everything went ok, the php_mapscript.so file will be
>>>>> located in the mapscript/php3/ directory.  Copy this file to your
>>>>> PHP extensions directory.   You can find the extensions directory
>>>>> by doing a ]$ php -i | grep extension_dir.
>>>>> You may want to rename php_mapscript.so to something like
>>>>> php_mapscript_MAPSERVERVERSION.so.
>>>>> There a setting in the pmapper config files called msVersion.  You
>>>>> must set this to MAPSERVERSION if you change the name of the file.
>>>>> Tim McGeary wrote:
>>>>>> So our installation of Mapserver, in combination, with PMapper, we
>>>>>> are getting an error that it cannot find php_mapserver.so.  While
>>>>>> I configured Mapserver to work with PHP, and it went through fine,
>>>>>> I cannot find the php_mapserver.so file anywhere on my server.
>>>>>> Was it supposed to be delivered in the mapserver package?  If so,
>>>>>> where would it have gone?  If not, where can I find it?
>>>>>> Thanks,
>>>>>> Tim
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
