[mapserver-users] finding php_mapserver.so
Bruce, Bob (CON)
Bob.Bruce at gov.mb.ca
Thu May 1 14:59:47 EDT 2008
Tim:
I believe that the problem is that you specified a trailing /
character in your name. Try using --with-php=/usr/include/php , I see
that the output from your configure has double / characters and that is
probably why you are not getting it to build the mapscript module.
Here are the messages that I got when I did the configure with the
option shown above:
checking for location of config.h or php_config.h...
/usr/include/php/main/php_config.h
checking whether we have PHP3 or PHP4... -DPHP4
checking whether we should use PHP's regex... yes
found regex_extra.h - building PHP MapScript with PHP's bundled
regex
PHP/MapScript module configured
And the php_mapscript.so file was built in the mapscript/php3 directory.
Bob Bruce
-----Original Message-----
Sent: Thursday, 01 May, 2008 10:09 AM
To: Kyle Wilcox; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] finding php_mapserver.so
I did specify the --with-php=DIR as --with-php=/usr/include/php/
Here's the output of the configure script for the PHP/Mapscript:
configure: checking for PHP/MapScript module options...
checking for g++ -shared ... yes
/usr/include/php//main/php_config.h
checking whether we have PHP3 or PHP4... -DPHP4 checking whether we
regex
PHP/MapScript module configured.
checking if --enable-runpath requested... no checking if
--with-java-include-os-name specified... no, autodetected linux
configure: creating ./config.status
config.status: creating Makefile
config.status: creating mapscript/php3/Makefile
config.status: creating mapscript/java/Makefile
config.status: creating mapscript/csharp/Makefile
MapServer is now configured for
-------------- Compiler Info -------------
C compiler: gcc -O2 -fPIC -Wall
C++ compiler: g++ -O2 -fPIC -Wall
Debug: -DNEED_NONBLOCKING_STDERR
Generic NINT:
Threading support:
-------------- Renderer Settings ---------
zlib support:
png support:
jpeg support: -DUSE_JPEG
iconv support: -DUSE_ICONV
AGG support:
AGG Freetype support:
Ming(flash) support:
PDFLib support:
-------------- Data Format Drivers -------
native tiff support: -DUSE_TIFF
PostGIS support:
Proj.4 support:
EPPL7 support: -DUSE_EPPL
ArcSDE support:
OGR support:
GDAL support:
GEOS support:
Oracle Spatial support:
FastCGI support:
-------------- OGC Services --------------
WMS Server:
WMS Client:
WFS Server:
WFS Client:
WCS Server:
SOS Server:
-------------- MapScript -----------------
PHP MapScript: yes
FYI, I'm running PHP 5.1.6
Tim
Tim McGeary
Senior Systems Specialist
Lehigh University
610-758-4998
tim.mcgeary at lehigh.edu
Google Talk: timmcgeary
Yahoo IM: timmcgeary
Kyle Wilcox wrote:
> Did you specify the --with-php=DIR?
> DIR is obviously the directory of the php version you want to use.
> Step through the output from ./configure and see what it says about
> PHP/Mapscript. I think it is towards the end.
> Tim McGeary wrote:
>> No, it isn't there. I did a:
>> find / -name php_mapscript.so
>> and it came up with nothing. So it isn't on the server at all. Yes,
>> I did install Mapserver from source.
>> Here's what is in mapscript/php3
>> [root at rust php3]# pwd
>> /usr/local/mapserver-5.0.2/mapscript/php3
>> [root at rust php3]# ls -l
>> total 716
>> drwxr-xr-x 2 root root 4096 Jan 28 10:56 examples
>> -rw-r--r-- 1 root root 2103 Jul 26 2004 hashtable_i.c
>> -rw-r--r-- 1 root root 4344 Apr 29 15:37 Makefile
>> -rwxr-xr-x 1 root root 3770 Jun 11 2007 Makefile.in
>> -rwxr-xr-x 1 root root 2097 Feb 14 2006 Makefile.vc
>> -rwxr-xr-x 1 root root 34328 Aug 16 2007 mapscript_i.c
>> -rw-r--r-- 1 root root 1049 Feb 14 2006 nmake.opt
>> -rwxr-xr-x 1 root root 502728 Jan 8 12:04 php_mapscript.c
>> -rwxr-xr-x 1 root root 16760 Aug 16 2007 php_mapscript.h
>> -rw-r--r-- 1 root root 17046 Jun 15 2007 php_mapscript_util.c
>> -rw-r--r-- 1 root root 7450 Jun 15 2007 php_mapscript_util.h
>> -rw-r--r-- 1 root root 25958 Jun 14 2005 php_proj.c
>> -rw-r--r-- 1 root root 3103 Jul 23 2007 php_regex.c
>> -rwxr-xr-x 1 root root 68315 Jan 8 12:04 README
>> -rwxr-xr-x 1 root root 3821 Jun 21 2001 README.WIN32
>> Thanks,
>> Tim
>> Tim McGeary
>> Lehigh University
>> 610-758-4998
>> Kyle Wilcox wrote:
>>> If you installed Mapserver from source with the ---with-php=DIR
>>> option and everything went ok, the php_mapscript.so file will be
>>> located in the mapscript/php3/ directory. Copy this file to your
PHP
>>> extensions directory. You can find the extensions directory by
>>> doing a ]$ php -i | grep extension_dir.
>>> You may want to rename php_mapscript.so to something like
>>> php_mapscript_MAPSERVERVERSION.so.
>>> There a setting in the pmapper config files called msVersion. You
>>> must set this to MAPSERVERSION if you change the name of the file.
>>> Tim McGeary wrote:
>>>> So our installation of Mapserver, in combination, with PMapper, we
>>>> are getting an error that it cannot find php_mapserver.so. While I
>>>> configured Mapserver to work with PHP, and it went through fine, I
>>>> cannot find the php_mapserver.so file anywhere on my server.
>>>> Was it supposed to be delivered in the mapserver package? If so,
>>>> where would it have gone? If not, where can I find it?
>>>> Thanks,
>>>> Tim
