[MAPSERVER-USERS] Any other Routing solution than
pgRouting/Oracle NDM ?
riteshambastha
ritesh.linux at gmail.com
Fri May 2 13:38:47 EDT 2008
Thanks Steve,
I am pretty sure your words are making a mapserver enthusiast's life very
easy.
For Route computation I am using a licensed version of Oracle Spatial DB.
Now, as PostGIS is looking so promising in the market, I am also thinking to
shift to PostGIS.
And after that, I will re-engineer my routing code using :
>pgRouting
>Ka-map xmlOverlay
I guess I am going in the right direction.
Regards,
Ritesh Ambastha
Stephen Woodbridge wrote:
> riteshambastha wrote:
>> Thanks Steve,
>> Route computation is taking an average time of 1.2 sec.
>> Post this, showing route on the browser takes a lot of time.
>> I am not using kamap xml overlay and any lib of openlayers.
>> I am posting this route result xml into a db, and allowing a map file to
>> read this db and show the route on map.
>> I know this is not an efficient way to do the job.
> I would start by adding some timing to a log file so you KNOW where your
> time is getting spent, then work on optimizing the larger times.
> I think this is the fastest way to go unless the route is relatively
> small in the number of nodes in the polyline. You should look at getting
> rid of the xml, in fact, why are you going to xml at all and then
> putting it back into the database. The data is being generate in the
> database then you extract it and format it into xml and then put the xml
> back into the database for mapserver to pick up. I think you should just
> put it into a table of routes with a unique sessionid+routeid key then
> pass the key to mapserver to use on selecting the right record.
>> I got to know that openlayers libs can help me to achieve the same. I
>> want
>> to know how in-efficient will be to use kamap xml overlay instead of any
>> fn
>> of openlayers.
> You can server the route as a wfs layer, but if it is complicated it
> might be too many points to handle quickly in the browser.
> -Steve
>> Regards,
>> Ritesh Ambastha
>>>> Dear friends,
>>>> I have seen routing based on postgis routing and oracle network data
>>>> models.
>>>> Even though, they serve the purpose very efficiently, they take some
>>>> 1sec/2sec/3sec to display the routes. I checked them with OpenLayers
>>>> and
>>>> Ka-map. Still, I feel there must be a way to reduce this route display
>>>> time.
>>>> Is there any any other ways to show routing/directions over mapserver
>>>> based
>>>> maps? Any other data structure and programming in C/python can serve
>>>> the
>>>> purpose ?
>>> What is taking too long?
>>> 1) is it the route computation
>>> 2) transfering the route data to OpenLayers
>>> 3) rendering the route data as a vector layer
>>> Have you considered writing some code on the server that generates an
>>> image file from the route data and returns a url for the image that can
>>> be then pinned to OpenLayers like a marker? You could do this by writing
>>> a wrapper in your favorite scripting language around the request to
>>> generate the route.
>>> -Steve W
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
View this message in context: http://www.nabble.com/Any-other-Routing-solution-than-pgRouting-Oracle-NDM---tp17001397p17024363.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
