[mapserver-users] How do I make a shapefile polygon thicker within UMN Mapserver
Jackey Cheung cheung.jackey at gmail.com
Thu May 8 22:59:18 EDT 2008
The good news is, if I recall correctly, starting from MapServer 5.0, the
WIDTH parameter affects the width of the outline of polygon layers.
On Fri, May 9, 2008 at 1:14 AM, Bart van den Eijnden (OSGIS) <
bartvde at osgis.nl> wrote:
> See the FAQ under section
>     How do I set line width in my maps?
> http://mapserver.gis.umn.edu/docs/faq
> Best regards,
> Bart
> John Mitchell wrote:
>> Hi,
>> How do I make a shapefile polygon thicker within UMN Mapserver?
>> I have listed below the layer that correctly displays the outlines
>> contained within the shapefile, but I can't figure out how to make the
>> polygon outlines thicker.
>> LAYER
>>  # name of layer
>>  NAME stlouisxdrive
>>  GROUP "gv:stlouisxdrive"
>>  PROJECTION
>>   "init=epsg:26915"
>>  END
>>    # what type of data is this?
>>  TYPE POLYGON
>>    DATA "C:/TEMP/64Resolution"
>>  # always returned with interface
>>  STATUS ON
>>        CLASS
>>        OUTLINECOLOR 255 0 0
>>        END
>>  END
>> John J. Mitchell
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> OSGIS, Open Source GIS
> bartvde at osgis.nl
> http://www.osgis.nl
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080509/008b16f7/attachment-0001.html
