[mapserver-users] testing mapserver	largefiles	rendering	improvements
    Burgholzer,Robert
    rwburgholzer at deq.virginia.gov
    Thu May 15 08:34:02 PDT 2008
If there is zero overhead to check for the existence of a ".qix" file
and determine if it is up to date, I think this is a good default (no
magic required).
As for making it work out of the box for the typical user who is not
interested in the nitty-gritty: Perhaps the "quick install" documents
could say "Step X: Run the shptree on all your shape files".
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Guillaume
Sueur
Sent: Thursday, May 15, 2008 11:24 AM
To: Daniel Morissette
Cc: Mapserver-users
Subject: Re: [mapserver-users] testing mapserver largefiles rendering
improvements
I'm not sure that "standard" user uses often msDebug().
My point was just to say that if somebody tries and tests MapServer,
he/she will only read the basic documentation to have a working mapfile
on a dataset. Once it works, no more reading will be done. And if a
large shape is tested, the user can then be disappointed.
The thing is that it's more than a specific tuning stuff, maybe more
than a GIST index on a postGIS database.
I think it should be mentionned at least in the Vector Data Access /
shapefiles doc of the website. In addition to "Shapefiles are made up of
a minimum of three similarly named files, with different suffixes..",
one could write : "having a .qix file made with shptree improves
considerabily the performances, mostly on large shapefiles"
Beside this, I like the idea of building a MapFile Optimizer too...
Daniel, what do you have in mind exactly ?
Guillaume
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
