[mapserver-users] Trouble compiling 5.0.2 with AGG on Centos 4
Guillaume Sueur guillaume.sueur at neogeo-online.net
Thu May 15 12:21:28 EDT 2008
try
--with-freetype=/usr/bin
and
--with-agg=/path/to/agg/build/dir
Guillaume
Dominik Schmid a écrit :
> We've finally decided to move forward and replace our ageing Mapserver
> 4.0.1 installation with the latest and greatest version.
> I came as far as thinking that the AGG make was successfull, but when I
>  try to configure Mapserver ("/.configure -with-agg --with-freetype") I
> get the following error:
> configure: error: freetype required for agg support - please configure
> --with-freetype
> I did include some directories with both options with the same result.
> I'm not sure where AGG is exactly installed (directly in "agg-2.x" or in
> a subdirectory in there) nor which freetype directory to use located
> (the libfreetype.* files are in "/usr/lib" but freetype-config is in
> "/usr/bin").
> When I check in yum I see that freetype 2.1.9 is in fact installed. One
> problem I see is with AGG, I can't get it through Centos 4 repositories
> so I guess need to compile it myself. I've tried various instructions:
> - http://trac.osgeo.org/mapserver/ticket/2215 (not sure if that's still
> valid info)
> - Rich Fromm's instructions posted on this list on Nov 27, 2007
> The instruction in ticket 2215 don't result in the promised
> agg_font_freetype.o file, neither in agg-2.4 nor agg-2.5.
> Rich's instructions for build AGG (". autogen.sh") exits with the
> following error:
> ./configure: line 4513: syntax error near unexpected token 'FREETYPE,'
> ./configure: line 4513: 'PKG_CHECK_MODULES(FREETYPE,'
> I'm kind of lost with this, so I'm turning to this list for help.
> Documentation for installing Mapserver 5 with AGG support seems scarce.
> Here's some more system info:
> - Centos 4.4
> - Apache 2.0.52
> - PHP 5.1.6
> - pgsql 8.1.8
> - freetype and freetype-devel 2.1.9
> ... I can give more specs if needed.
> Any help is greatly appreciated
> Dominik
