[MAPSERVER-USERS] color coding
Ritesh Ambastha
group.ritesh at gmail.com
Thu May 15 15:16:50 EDT 2008
Dear Kevin,
Shortcuts are never good. You should write everything by yourself in the
mapfile.
Still, if you want to give a try, follow this shortcut.
Install http://www.qgis.org/ QGIS (Freely available).
Also, install http://www.python.org python (Freely available)
Now, you can use QGIS as a desktop software where you can add multiple
shapefiles, and play with them by giving required color combo's. Once you
are satisfied with the color codes etc, you can EXPORT the rendered map into
.map file format.
Use this map file for rendering maps. That's all !
[I don't advice to use this way to generate map files]
Regards,
Ritesh
Kevin Edmundson wrote:
> I have a layer that I want to color code the features for a specific
> field.
> Is there a way in mapserver to have it automatically color all unique
> values, or do I specifically have to identify the unique value/color
> combinations myself in class items?
> Kevin Edmundson
> CIO
> WTH Technology, Inc
> 567 W Westfield Blvd
> Indianapolis, IN 46208
> 317.259.0105 office
> 317.259.1423 fax
> 317.501.8560 mobile
> kevin.edmundson at wthtechnology.com
> NOTICE: This message is from the technology firm WTH Technology, Inc.
> This message is intended only for the individual or entity to which it
> is directed. If you are not the addressee, or if this message has been
> addressed to you in error, you are not authorized to use, read, copy or
> distribute this message and any attachments, and we ask that you please
> immediately delete this message and attachments (including all copies),
> and notify the sender by return e-mail so that our records can be
> corrected. All personal messages express views only of the sender, which
> are not to be attributed to WTH Technology, Inc, and may not be
> distributed or copied without this statement.
> mapserver-users at lists.osgeo.org
View this message in context: http://www.nabble.com/color-coding-tp17239428p17260414.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
