[MAPSERVER-USERS] GD 2.0.35 installed but not found
TallDave notice at davidbianco.net
Thu May 15 17:22:45 EDT 2008
First time mapserver install.   Below is my config script and output.  Any
insight into why libgd is not working out here?    I am running this on
Solaris 9.  As you can see libgd.so definitely exists in the required
directory and it has no problem accessing jpeg, freetype, png, iconv.
Thanks!
Dave
unix:mapserver-5.0.2> cat conf_mapserv.sh
# MapServer configure command
# May 2 2008
./configure --with-debug \
            --with-freetype \
            --with-zlib \
            --with-png \
            --with-jpeg \
            --with-libiconv \
            --with-gd=/usr/local/lib  \
            --with-proj  \
            --with-threads \
            --with-ogr  \
            --with-gdal  \
            --with-tiff  \
            --with-oraclespatial  \
            --with-wfs \
            --with-wcs \
            --with-wfsclient \
            --with-wmsclient \
            --with-curl-config  \
            --with-warnings \
            --enable-debug
unix:mapserver-5.0.2> cat install_mapserver.log
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for ranlib... ranlib
checking for flex... flex
checking for yywrap in -lfl... yes
checking lex output file root... lex.yy
checking whether yytext is a pointer... yes
checking for bison... bison -y
checking if compiler supports -R... yes
checking for exp in -lm... yes
checking for __gxx_personality_v0 in -lstdc++... yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for strcasecmp... yes
checking for strncasecmp... yes
checking for strdup... yes
checking for strlcat... yes
checking for vsnprintf... yes
MapServer Version from mapserver.h: '5.0.2'
configure: checking where FreeType 2.x is installed...
checking for freetype-config... /usr/local/bin/freetype-config
        using libfreetype from -L/usr/local/lib -R/usr/local/lib -lfreetype
-lz
checking for FT_Init_FreeType in -lfreetype... yes
        using libfreetype -lfreetype from system libs.
configure: checking where Zlib is installed...
checking for zlibVersion in -lz... yes
        using libz from system libs (-DUSE_ZLIB).
configure: checking where PNG is installed...
checking for png_init_io in -lpng... yes
        using libpng from system libs.
configure: checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
        using libjpeg from system libs.
configure: checking where libXpm is installed...
        using libXpm from -L/lib -lXpm -lX11
configure: checking where libiconv is installed...
checking for iconv_open in -lc... yes
checking for libiconv_open in -liconv... yes
        using libiconv from -L -liconv
        libiconv found. Enabling internationalization (-DUSE_ICONV)
configure: checking for GD 2.0.16 or higher...
checking for gdFontCacheSetup in -lgd... no
configure: checking whether GD needs libiconv...
configure: error: Could not find gd.h or libgd.a/libgd.so in /usr/local/lib.
Make sure GD 2.0.16 or higher is compiled before calling configure. You may
also get this error if you didn't specify the appropriate location for one
of GD's dependencies (freetype, libpng, libjpeg or libiconv).
unix:mapserver-5.0.2> ls -l /usr/local/lib/libgd.*
-rw-r--r--   1 root     other     806416 May  2 14:33 /usr/local/lib/libgd.a
-rwxr-xr-x   1 root     other       1055 May  2 14:33
/usr/local/lib/libgd.la*
lrwxrwxrwx   1 root     other         14 May  2 14:33
/usr/local/lib/libgd.so -> libgd.so.2.0.0*
/usr/local/lib/libgd.so.2 -> libgd.so.2.0.0*
-rwxr-xr-x   1 root     other     815700 May  2 14:33
/usr/local/lib/libgd.so.2.0.0*
unix:mapserver-5.0.2> grep VERSION /usr/local/include/gd.h
#define GD_MAJOR_VERSION 2
#define GD_MINOR_VERSION 0
#define GD_RELEASE_VERSION 35
#define GD_EXTRA_VERSION ""
#define GD_VERSION_STRING "2.0.35"
View this message in context: http://www.nabble.com/GD-2.0.35-installed-but-not-found-tp17262832p17262832.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
