[MAPSERVER-USERS] GD 2.0.35 installed but not found
alim karim alim.karim at gmail.com
Fri May 16 11:14:47 EDT 2008
dave,
i got this error just yesterday.
the configure worked for me after re-installing gd with fontconfig support
(this was on a gentoo machine)
if you notice, the output just before configure bails is - checking for
gdFontCacheSetup in -lgd... no
configure.log might be able to give you more ideas as well. i'd try the
fontconfig support first.
ak
On 5/15/08, TallDave <notice at davidbianco.net> wrote:
> First time mapserver install.   Below is my config script and output.  Any
> insight into why libgd is not working out here?    I am running this on
> Solaris 9.  As you can see libgd.so definitely exists in the required
> directory and it has no problem accessing jpeg, freetype, png, iconv.
> Thanks!
> Dave
> unix:mapserver-5.0.2> cat conf_mapserv.sh
> # MapServer configure command
> # May 2 2008
> ./configure --with-debug \
>             --with-freetype \
>             --with-zlib \
>             --with-png \
>             --with-jpeg \
>             --with-libiconv \
>             --with-gd=/usr/local/lib  \
>             --with-proj  \
>             --with-threads \
>             --with-ogr  \
>             --with-gdal  \
>             --with-tiff  \
>             --with-oraclespatial  \
>             --with-wfs \
>             --with-wcs \
>             --with-wfsclient \
>             --with-wmsclient \
>             --with-curl-config  \
>             --with-warnings \
>             --enable-debug
> unix:mapserver-5.0.2> cat install_mapserver.log
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking for ranlib... ranlib
> checking for flex... flex
> checking for yywrap in -lfl... yes
> checking lex output file root... lex.yy
> checking whether yytext is a pointer... yes
> checking for bison... bison -y
> checking if compiler supports -R... yes
> checking for exp in -lm... yes
> checking for __gxx_personality_v0 in -lstdc++... yes
> checking how to run the C preprocessor... gcc -E
> checking for egrep... grep -E
> checking for ANSI C header files... yes
> checking for strcasecmp... yes
> checking for strncasecmp... yes
> checking for strdup... yes
> checking for strlcat... yes
> checking for vsnprintf... yes
> MapServer Version from mapserver.h: '5.0.2'
> configure: checking where FreeType 2.x is installed...
> checking for freetype-config... /usr/local/bin/freetype-config
>         using libfreetype from -L/usr/local/lib -R/usr/local/lib -lfreetype
> -lz
> checking for FT_Init_FreeType in -lfreetype... yes
>         using libfreetype -lfreetype from system libs.
> configure: checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
>         using libz from system libs (-DUSE_ZLIB).
> configure: checking where PNG is installed...
> checking for png_init_io in -lpng... yes
>         using libpng from system libs.
> configure: checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... yes
>         using libjpeg from system libs.
> configure: checking where libXpm is installed...
>         using libXpm from -L/lib -lXpm -lX11
> configure: checking where libiconv is installed...
> checking for iconv_open in -lc... yes
> checking for libiconv_open in -liconv... yes
>         using libiconv from -L -liconv
>         libiconv found. Enabling internationalization (-DUSE_ICONV)
> configure: checking for GD 2.0.16 or higher...
> checking for gdFontCacheSetup in -lgd... no
> configure: checking whether GD needs libiconv...
> configure: error: Could not find gd.h or libgd.a/libgd.so in
> /usr/local/lib.
> Make sure GD 2.0.16 or higher is compiled before calling configure. You may
> also get this error if you didn't specify the appropriate location for one
> of GD's dependencies (freetype, libpng, libjpeg or libiconv).
> unix:mapserver-5.0.2> ls -l /usr/local/lib/libgd.*
> -rw-r--r--   1 root     other     806416 May  2 14:33
> /usr/local/lib/libgd.a
> -rwxr-xr-x   1 root     other       1055 May  2 14:33
> /usr/local/lib/libgd.la*
> lrwxrwxrwx   1 root     other         14 May  2 14:33
> /usr/local/lib/libgd.so -> libgd.so.2.0.0*
> /usr/local/lib/libgd.so.2 -> libgd.so.2.0.0*
> -rwxr-xr-x   1 root     other     815700 May  2 14:33
> /usr/local/lib/libgd.so.2.0.0*
> unix:mapserver-5.0.2> grep VERSION /usr/local/include/gd.h
> #define GD_MAJOR_VERSION 2
> #define GD_MINOR_VERSION 0
> #define GD_RELEASE_VERSION 35
> #define GD_EXTRA_VERSION ""
> #define GD_VERSION_STRING "2.0.35"
> http://www.nabble.com/GD-2.0.35-installed-but-not-found-tp17262832p17262832.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080516/fa0b494a/attachment-0001.html
