[mapserver-users] GDAL netcdf/hdf driver and WMS/WCS,
file not found (path error)
Maarten Plieger
plieger at knmi.nl
Mon May 19 09:07:05 EDT 2008
Hello,
I am using the netcdf and hdf5 drivers from GDAL to output images and
data to the WMS and WCS services from UMN MapServer. When using an
absolute path for these kind of files, the files are not found by
mapserver.
For example a piece of my mapfile:
NAME "netcdf"
DATA 'NETCDF:"/nobackup/users/plieger/mapdata/no2_200803.nc":Band1'
MapServer cannot find:
/nobackup/users/plieger/mapdata/NETCDF:"/nobackup/users/plieger/mapdata/no2_200803.nc":Band1
The filename should be
What is wrong: mapserver puts the path
"/nobackup/users/plieger/mapdata/" before "NETCDF".
Therefore I changed in mapstring.c at line 415:
[code]
/* Check if path is absolute */
if((abs_path == NULL) || (abslen == 0) ||
(path[0] == '\\') || (path[0] == '/') ||
(pathlen > 1 && (path[1] == ':'))
[/code]
to:
[code]
(pathlen > 1 && (path[1] == ':'))||
(strstr(path,":\"")>0)
[/code]
So " || (strstr(path,":\"")>0)" is added.
The code looks at the :" tokens occuring in the filename, when these
tokens occur the path should not be added to the filename.
(This is because NETCDF: should be at the start of the filename, so that
GDAL knows which driver to choose)
It is a solution for me for now, but i think that there is a better way
to solve it, without using "ststr".
Best Regards,
Maarten Plieger
Maarten Plieger
KNMI, R&D Information and Observation Technology, De Bilt
(t) +31 30 2206330
