[MAPSERVER-USERS] wms server, serve layers in multiple projections
Neil Best
nbest at LANWORTH.COM
Tue May 20 09:36:31 EDT 2008
Maria Panagou wrote:
> I am wondering if it is possible to setup a WMS server with Mapserver,
> that will serve layers in more than one map projection. For example it it
> possible to declare at MAP level such a PROJECTION declaration?
> PROJECTION
> "init=epsg:900913"
> "init=epsg:4326"
> END
Maria, my understanding is that the projection(s) that you want to advertise
for your service should be listed in the WEB stanza METADATA block with the
"wms_srs" tag. If you use a MAP-level projection and no wms_srs metadata
then your service will advertise that single projection. If wms_srs is
defined then the MAP-level PROJECTION simply becomes a default for Mapserver
to apply to your data sources. See the WMS Server HOWTO for more details:
http://mapserver.gis.umn.edu/docs/howto/wms_server
Neil
View this message in context: http://www.nabble.com/wms-server%2C-serve-layers-in-multiple-projections-tp15909153p17340367.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
