[MAPSERVER-USERS] WMS server with non-EPSG SRS?
Frank Warmerdam
warmerdam at pobox.com
Tue May 20 11:00:04 EDT 2008
Neil Best wrote:
> I have been trolling the list for any sense of attempts to use or prospects
> for ever using non-EPSG SRSs with a WMS server. Somewhere I found a post, I
> think it was this list but don't have the link handy, from 2001 saying that
> there had been discussion to generalize the mechanism for advertising SRSs
> in order to go beyond those defined in the epsg support file that ships with
> proj, which suggests the possibility of advertising arbitrary projections,
> not just those in the assorted support files. I find myself in the
> uncomfortable situation of trying to deliver my USGS-modified Albers equal
> area ("proj -v +init=other.extra:42303") to a client in USA Contiguous
> Lambert Conformal Conic ("proj -v init=esri:102004", also in esri.extra,
> http://spatialreference.org/ref/epsg/102004/). I have seen proj and ogr2ogr
> respect the use of these other proj support files, but as far as I know
> Mapserver does not, never mind that the WMS spec appears to only accommodate
> EPSG-listed SRSs. Is there any indication that this situation will change,
> either through an extension to the WMS spec or other means?
Neil,
The normal practice if you want a non-EPSG coordinate system to be usable
for WMS serving with MapServer is to just extend the epsg init file with
the definition. Is this unacceptable for some reason?
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
