[mapserver-users] SDE 9.2 Connection Type
Josh Hevenor jhevenor at rogers.com
Mon May 26 11:41:13 EDT 2008
Just a quick note while I'm thinking of it...with the relatively recent
support of SDE 9.2 the style has changed to use a plug-in. So if you're
looking for a layers connection type in MapScript is will show up as 13
instead of MS_SDE (6 I think?). I don't see a documented constant for
the plugiin connection type.
Cheers,
Josh Hevenor
