[mapserver-users] SDE 9.2 Connection Type
Daniel Morissette
dmorissette at mapgears.com
Mon May 26 15:04:22 EDT 2008
Josh Hevenor wrote:
> Just a quick note while I'm thinking of it...with the relatively recent
> support of SDE 9.2 the style has changed to use a plug-in. So if you're
> looking for a layers connection type in MapScript is will show up as 13
> instead of MS_SDE (6 I think?). I don't see a documented constant for
> the plugiin connection type.
I presume you are using PHP MapScript? Thanks for reporting the issue. I
have filed a ticket and added the missing constants (there were actually
two):
http://trac.osgeo.org/mapserver/ticket/2630
Daniel
Daniel Morissette
http://www.mapgears.com/
