[mapserver-users] Using dimensions with MapServer as WMS client
Alexandre Saunier
alexandre.saunier at camptocamp.com
Tue May 27 06:50:38 EDT 2008
Thanks for the reply.
> Only wms_time is supported by mapserver acting as a wms server.
I guess you meant "acting as a wms client"?
That would explain why metadata such as
"wms_dimension_elevation_uservalue" seem to be ignored.
A workaround would be to directly add the additional parameters in the
CONNECTION attribute, by hand in the mapfile or on the fly using
mapscript method layerObj::set('connection', ...).
Yewondwossen Assefa wrote:
> Alexandre,
> Only wms_time is supported by mapserver acting as a wms server. It is
> also the only dimension that is advertised through the capabilities
> document. From what I can I see the map context only loads/save the
> dimension into Mapserver metadata, but it is not used for anything.
> Best Regards,
> Alexandre Saunier wrote:
>> Hello,
>> I use Mapserver 5.0.2 as a client sending GetMap requests to some WMS
>> server. Requests should contain additional parameters such as "time" and
>> "elevation". For instance:
>> wms?LAYERS=...&REQUEST=GetMap&SERVICE=WMS&BBOX=...&TIME=...&ELEVATION=...
>> Using a "wms_time" metadata in the layer definition in the mapfile, I
>> have succeeded in adding the "TIME" parameter to the request.
>> On the other hand, in order to add the "ELEVATION" parameter I have
>> tried to use the "wms_dimension*" metadata parameters as described in
>> http://mapserver.gis.umn.edu/docs/howto/mapcontext#layer-object-metadata
>> but couldn't have them taken into account. For instance:
>> LAYER
>> NAME "foobar"
>> TYPE RASTER
>> CONNECTION "http://foobar/wms?"
>> CONNECTIONTYPE WMS
>> METADATA
>> "wms_srs" "EPSG:4326"
>> "wms_name" "foobar"
>> "wms_server_version" "1.1.1"
>> "wms_format" "image/jpeg"
>> "wms_title" "Foobar"
>> "wms_onlineresource" "http://foobar/wms?"
>> "wms_time" "2007-06-13T12:00:00Z"
>> "wms_dimension_elevation_uservalue" "100.0"
>> END
>> END
>> I have also tried to add other wms_dimension* parameters (such as
>> wms_dimensionlist or wms_dimension_elevation_default) as listed in the
>> manual example but with no success. In addition it seems that using
>> "wms_dimension_time_uservalue" instead of "wms_time" does not work
>> either.
>> Thus I was wondering what were the required wms_dimension* parameters to
>> add a dimension in a WMS GetMap performed by Mapserver and if there
>> were some extra settings needed to enable dimensions support?
>> Thanks for your help,
>> Alexandre
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
