[mapserver-users] Using dimensions with MapServer as WMS client
Yewondwossen Assefa
yassefa at dmsolutions.ca
Mon May 26 14:26:11 EDT 2008
Alexandre,
Only wms_time is supported by mapserver acting as a wms server. It is
also the only dimension that is advertised through the capabilities
document. From what I can I see the map context only loads/save the
dimension into Mapserver metadata, but it is not used for anything.
Best Regards,
Alexandre Saunier wrote:
> Hello,
> I use Mapserver 5.0.2 as a client sending GetMap requests to some WMS
> server. Requests should contain additional parameters such as "time" and
> "elevation". For instance:
> wms?LAYERS=...&REQUEST=GetMap&SERVICE=WMS&BBOX=...&TIME=...&ELEVATION=...
> Using a "wms_time" metadata in the layer definition in the mapfile, I
> have succeeded in adding the "TIME" parameter to the request.
> On the other hand, in order to add the "ELEVATION" parameter I have
> tried to use the "wms_dimension*" metadata parameters as described in
> http://mapserver.gis.umn.edu/docs/howto/mapcontext#layer-object-metadata
> but couldn't have them taken into account. For instance:
> LAYER
> NAME "foobar"
> TYPE RASTER
> CONNECTION "http://foobar/wms?"
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_name" "foobar"
> "wms_server_version" "1.1.1"
> "wms_format" "image/jpeg"
> "wms_title" "Foobar"
> "wms_onlineresource" "http://foobar/wms?"
> "wms_time" "2007-06-13T12:00:00Z"
> "wms_dimension_elevation_uservalue" "100.0"
> END
> END
> I have also tried to add other wms_dimension* parameters (such as
> wms_dimensionlist or wms_dimension_elevation_default) as listed in the
> manual example but with no success. In addition it seems that using
> "wms_dimension_time_uservalue" instead of "wms_time" does not work either.
> Thus I was wondering what were the required wms_dimension* parameters to
> add a dimension in a WMS GetMap performed by Mapserver and if there
> were some extra settings needed to enable dimensions support?
> Thanks for your help,
> Alexandre
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
