[MAPSERVER-USERS] Displaying population density with Mapserver
Pierre-Benoit Besse besse.pb at gmail.com
Tue May 27 12:25:50 EDT 2008
Ha, well, I prefer that :) I would need a lot of layer definitions to obtain
something ok...
But I just tried the "ground units" stuff, I tried with a 50 kilometers wide
square and it drew squares the size of ASIA !! oO
I had to define a 1 feet wide square to obtain something more or less ok...
Does anybody know why ?
Aside from that It seems to work, thank you !
I will try the scalesymbol stuff tomorrow.
Regards
2008/5/27 Fawcett, David <David.Fawcett at state.mn.us>:
> Before you create lots of different layers to simulate symbol scaling,
> you may want to try something else.  It has been a long time since I
> have played with scaled symbols, but give it a try.
> You should be able to scale the symbols by setting a SYMBOLSCALE in the
> LAYER object.  This is the scale at which you want the symbol to appear
> at the SIZE stated in the map file.
> You may want to modify STYLE MAXSIZE if you think that you will want
> your symbols to be larger than 50 pixels.
> Another completely different approach that just came to my mind would be
> to use ground units (e.g. meters) to set the size of your symbol.  To do
> this, set LAYER SIZEUNITS to meters.  Calculate the size of a symbol in
> meters on the ground that will touch adjacent symbols, or give you the
> desired amount of space between the symbols.  That way, the symbols
> should scale consistently.
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ritesh
> Ambastha
> Sent: Tuesday, May 27, 2008 10:16 AM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [MAPSERVER-USERS] Displaying population density with
> Mapserver
> Dear Faldor,
> Robert is absolutely right. You will have to make different LAYERS for
> the same POINT layer. But, define MAX/MINSCALE for each Layer. Change
> STYLE -> SIZE values in each of the layer. You are done !!
> Cheers !
> Ambastha
> Faldor wrote:
> > Yes, but I need them to adapt for different extents.
> > For example, When I zoom out enough to see the world, I need them 1
> > pixel wide (it's ugly otherwise), but when I zoom in I will need then
> > 2 or 5 or even 30 pixels wide to cover all space.
> > 2008/5/27 Ritesh Ambastha <group.ritesh at gmail.com>:
> >> Dear Faldor,
> >> <snip>What I need is to have the points grow to cover all space
> >> available when I zoom in.</snip>
> >> Do you mean that the size of points should grow? It can be done
> >> easily by setting proper SIZE in the STYLE tag.
> >> Regards,
> >> Ambastha
> >> Faldor wrote:
> >> > Hi,
> >> > Sorry for my first empty message.
> >> > My problem is, I need to display population density with Mapserver.
> >> > The data comes from GPWv3 and has a resolution of 15'. I converted
> >> > it to a POINT Shapefile using ogr2ogr.
> >> > At first when I display it on a world map it shows nicely. But when
> >> > I
> >> zoom
> >> > in it begins to show separated points for each value in the
> >> > shapefile. What I need is to have the points grow to cover all
> >> > space available
> >> when
> >> I
> >> > zoom in.
> >> > Is there any mean to do it with Mapserver ? I did not find it in
> >> > the mapfile reference.
> >> > I don't know if I explained it well (I'm not english speaking). If
> >> > you
> >> do
> >> > not understand something, please ask.
> >> > Cordialy,
> >> > Faldor
> >> View this message in context:
> >> http://www.nabble.com/Displaying-population-density-with-Mapserver-tp
> >> 17492210p17492387.html
> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapserver-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> http://www.nabble.com/Displaying-population-density-with-Mapserver-tp174
> 92210p17492783.html
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080527/185c6820/attachment.html
