[MAPSERVER-USERS] Displaying population density with Mapserver
Fawcett, David
David.Fawcett at state.mn.us
Tue May 27 12:29:10 EDT 2008
Have you defined an output projection for your map and input projections
for each of your layers? It is likely that MapServer needs to know what
the input projection/SRS is before it can translate to different units.
David.
-----Original Message-----
From: Pierre-Benoit Besse [mailto:besse.pb at gmail.com]
Sent: Tuesday, May 27, 2008 11:26 AM
To: Fawcett, David
Cc: Ritesh Ambastha; mapserver-users at lists.osgeo.org
Subject: Re: [MAPSERVER-USERS] Displaying population density
with Mapserver
Ha, well, I prefer that :) I would need a lot of layer
definitions to obtain something ok...
But I just tried the "ground units" stuff, I tried with a 50
kilometers wide square and it drew squares the size of ASIA !! oO
I had to define a 1 feet wide square to obtain something more or
less ok...
Does anybody know why ?
Aside from that It seems to work, thank you !
I will try the scalesymbol stuff tomorrow.
Regards
2008/5/27 Fawcett, David <David.Fawcett at state.mn.us>:
Before you create lots of different layers to simulate
symbol scaling,
you may want to try something else. It has been a long
time since I
have played with scaled symbols, but give it a try.
You should be able to scale the symbols by setting a
SYMBOLSCALE in the
LAYER object. This is the scale at which you want the
symbol to appear
at the SIZE stated in the map file.
You may want to modify STYLE MAXSIZE if you think that
you will want
your symbols to be larger than 50 pixels.
Another completely different approach that just came to
my mind would be
to use ground units (e.g. meters) to set the size of
your symbol. To do
this, set LAYER SIZEUNITS to meters. Calculate the size
of a symbol in
meters on the ground that will touch adjacent symbols,
or give you the
desired amount of space between the symbols. That way,
the symbols
should scale consistently.
David.
[mailto:mapserver-users-bounces at lists.osgeo.org] On
Behalf Of Ritesh
Ambastha
Sent: Tuesday, May 27, 2008 10:16 AM
To: mapserver-users at lists.osgeo.org
density with
Mapserver
Dear Faldor,
Robert is absolutely right. You will have to make
different LAYERS for
the same POINT layer. But, define MAX/MINSCALE for each
Layer. Change
STYLE -> SIZE values in each of the layer. You are done
Cheers !
Ambastha
Faldor wrote:
> Yes, but I need them to adapt for different extents.
> For example, When I zoom out enough to see the world,
I need them 1
> pixel wide (it's ugly otherwise), but when I zoom in I
will need then
> 2 or 5 or even 30 pixels wide to cover all space.
> 2008/5/27 Ritesh Ambastha <group.ritesh at gmail.com>:
>> Dear Faldor,
>> <snip>What I need is to have the points grow to cover
all space
>> available when I zoom in.</snip>
>> Do you mean that the size of points should grow? It
can be done
>> easily by setting proper SIZE in the STYLE tag.
>> Regards,
>> Ambastha
>> Faldor wrote:
>> > Hi,
>> > Sorry for my first empty message.
>> > My problem is, I need to display population density
with Mapserver.
>> > The data comes from GPWv3 and has a resolution of
15'. I converted
>> > it to a POINT Shapefile using ogr2ogr.
>> > At first when I display it on a world map it shows
nicely. But when
>> > I
>> zoom
>> > in it begins to show separated points for each
value in the
>> > shapefile. What I need is to have the points grow
to cover all
>> > space available
>> when
>> I
>> > zoom in.
>> > Is there any mean to do it with Mapserver ? I did
not find it in
>> > the mapfile reference.
>> > I don't know if I explained it well (I'm not
english speaking). If
>> > you
>> do
>> > not understand something, please ask.
>> > Cordialy,
>> > Faldor
>> View this message in context:
http://www.nabble.com/Displaying-population-density-with-Mapserver-tp
>> 17492210p17492387.html
>> Sent from the Mapserver - User mailing list archive
at Nabble.com.
>> mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
http://www.nabble.com/Displaying-population-density-with-Mapserver-tp174
92210p17492783.html
Sent from the Mapserver - User mailing list archive at
Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080527/84cb7bce/attachment-0001.html
